Have a question? Ask Woody!
What is best way to remove veneer tape
Sanding clogs sanding media. Scraping is slow. I have thought about wetting but haven't tried it.
BTW, the veneer is Queensland Walnut, AKA Oriental Wood. I have a 75 piece flitch of this thickly cut veneer if anyone wants to buy some.
Re: What is best way to remove veneer tape
Ralph Lipeles
I would assume that the pieces of tape were put there to pull cracked sections back together. With that in mind, I would leave the tape in place until the veneer was glued in place. Then I would remove the tape by wetting it to soften the glue.
Lee Grindinger
Yeah, careful wetting
Lee Grindinger
It is a PIA, no doubt. I found wetting was the most effective going one piece to the next until the tape peels up. Depending on the glue you used to stick the veneer too much water is obviously a bad thing. It leaves behind a bit of the tape glue that sands easily.
Get it barely damp, then use a card scraper
Thickness?
...all things being relative. When I was doing a lot of veneering, say 30 years ago, standard veneer thickness was 1/28". I could get 1/16" veneers in some species, particularly mahogany. When I resawed my own, I made them about 1/10" thick. Nowadays, it seems like veneers are sold at 1/40" or thinner. What do you consider thickly cut?
Nice looking wood, by the way. Where'd you get it?
jessecloud
Spritz a modest amont of water, scrape with a card scraper - wiping off debris after each scrape.
Comes right off.
thanks all
wetting it will be. For (apparently) no good reason I fretted over wetting. I guess all I need to worry about is getting it dry again before refining the surface. I am thinking I will use a damp 1" foam brush for wetting to confine the wet to the tape.
Moisture on veneer
Dick Coers
If you use a PVA glue to adhere the veneer, you're going to introduce a lot more moisture than the little needed to remove the gum tape. Not so much if you use a catalyzed adhesive.
good point
Sometimes I fret over things I don't need to.
I recall loading some lumber in the rain once and the surface was getting wetted on the way to the truck. Customer was fretting. I pointed out that at 7% moisture content a 20 pound board was going to already have more than a pint of water in it. The piddly amount on the surface was of no importance.
don stephan
The method I learned was to wet the entire surface with a sponge for a minute or so until the tape adhesive is softened. This takes longer because I am using solid, not perforated, veneer tape.
This will raise the grain of the veneer, but it's going to need at least that much sanding anyway.
Wetting the entire surface also should show any bubbles where the adhesive failed.
William Duffield
Wipe off the scraper, too, or clean it with a fingernail. The glue gets in behind the hook and clogs it so it stops cutting.
Re: good point
Sgian Dubh
Wetting probably is the most effective way of loosening and removing the tape. I use a damp cloth and concentrate the wetting on the tape itself over a period of 5 - 10 minutes. After that the tape lifts off easily with fingers alone in my experience, no scraping required. Where there's a double or triple layer of tape (if any) a bit more wetting is required.
However, be wary of being less than meticulous with the surface preparation after removing the tape because the glue residue does need thorough removal to prevent it grinning through any polish - in your example as a series of circles. Slainte.
