I don't get that ..
"And one disadvantage
There is one surprising difference with helical cutter heads over straight-knife machines: Helical cutter heads take more effort to feed. If you were to install a helical cutter in your jointer, you will notice that it takes more effort to push the board through the machine. The reason is simple. Previously, the wood only met with resistance from the spinning knives three or four times per rotation (depending on how many knives your machine has). With a helical cutter head, there is always at least one knife in contact with the wood, thus constant resistance to your push. As a result of this, planers and jointers typically use more horsepower when a helical cutter head is installed."
This won't help those driveline issues!
https://www.canadianwoodworking.com/tools/introduction-helical-cutter-heads
That is contrary to all I have read, and in my experience.
I have a Hammer A3-31 with spiral heads. The machine is recommended to use 20 amps. That may be the case, but I believe the recommendation was made when the straight blades were the only option. My machine is plugged into a 15 amp plug, and is very happy. In fact, under load, an electrician friend of mine measured the load needs at below 10 amps.
As I understand it, the impact of a single, straight blade striking the wood is far greater than several small blades that are both angled for a slicing cut, as well as spaced (on a spiral) for individual strikes.
This must reduce impact force. As an analogy, it is the same for a shooting board using a plane with a skewed blade, or a ramped shooting board with a straight blade. Both of these offer a progressive cut and create less impact than a flat shooting board with straight blade.
