THE WOODRAT IS BACK!
Delta 22-660 oil question
Michael van pelt
Manual says "extreme pressure gear oil". Any recommendations what I could find locally ?
Thanks
Mike
Re: Delta 22-660 oil question
Tractor Supply?
John Foster
Where is local?
John Foster
The lubricant guy at work thinks that the Mobil SHC 600 series synthetic gear oils should suffice. There are about 10 grades in that series, you would have to do a bit of reading to see what you needed. A Google image search shows containers from 1 quart up to barrels. Even though it is a specialty oil, I would imagine most service stations and machinery repair shops have accounts with Mobil, they should be able to order in what you want.
ben d.
The manual doesn't say but I would suspect it is an 80-90 wt. oil.
Any parts store or oil supply company should have it just ask for EP 80/90 weight oil.
The EP of course stands for extreme pressure which means the planer gears under load will not squeeze the lube from between the gears and lose lubrication causing wear on the gears and gear failure.
ben d.
Re: Delta 22-660 oil question *LINK*
Bob Entwisle in NJ
Michael,
I googled "Delta 22-660 extreme pressure gear oil"
And it came up with this.
(from the linked site)
"The machine was originally filled with approximately 6 ounces of 140 weight, EP (extreme pressure), gear oil.
If adding oil, use 140 wt. EP gear oil.
If changing oil, either 140 wt. EP gear oil, or 85-140 wt, multi-viscosity EP gear oil may be used. Fill to the filler hole.
The 85W140 with EP Additive is available as Delta service part number 999010131210.
DO NOT MIX oils of different types or viscosities."
Hope this helps.
Bob in NJ
Delta 22-660 gear oil
Michael van pelt
thanks WowWhat a grear group!
