OT, Memory Foam Topper question
A friend got a bunch of memory foam mattress toppers at a freight auction. They are apparently new old stock, old being the operative word. I took one home and opened it. Thought it was going practically explode. Nope. It was a real struggle to get it unrolled. Left it laying out over night. Only slightly puffed up. Now, 12 hours later its about 3/4 inflated.
So, is this how they work or has this foam lost its memory? He has about 20 of these and it would be a shame if they have died of old age in the package. They are for resale, but not if they are dead.
Re: OT, Memory Foam Topper question
Lee Schierer in McKean, PA
Be careful with your mattress. I made a head board for my son and his wife that was finished with a lacquer based finish. It was 5 years old when they purchased memory foam pillows. Within a short wile, they noticed that the pillows were sticking to the head board. I did some research and it seems that memory foam out gases for some period of time and those fumes can soften lacquer.
Lee
Maybe it has alzheimer's
Bob Lang
Give it another day or two. Most foams take some time to fully expand to their initial state. This is one of the problems with foam as furniture cushions. Those foams take 24 hours to return to their uncompressed state, but most likely someone will sit down before that happens.
Bob Lang
Karl_TN
Memory foam doesn't work so well in the cold. Are you letting it expand somewhere where it's pretty warm?
For the first 24 hours it was at my house and now its at the office where its room temperature. It better than it was, but still does not look like something you would want to sleep on. Lots of ridges and several flat spots.
Wonder if warmer would be better? Is there anything you can wet it with to rejuvenate it?
The one I took was in an open box and has some slight discoloration along an edge that was exposed int he carton. Can not imagine that to ones in the sealed cardboard boxes would be significantly better.
Karl_TN
The warmer the better, and don't worry about the discoloration any since it will be covered up. Leaving the memory foam out in the hot sun for a few hours might help, but it's the wrong season for doing that.
Tip: Memory foam over two inches thick that gets soaked (i.e. for cleaning) won't dry out without using some extreme measures. Don't do get your memory foam wet unless it's your last resort before throwing it out.
