Re: OT: Oil Change
Grant Smith
Hi Stuart,
Most owners manuals I have read have a mileage limit and a time limit on motor oil.
It isn't that the oil goes bad, rather it is the contaminants it can pick up from a vehicle sitting for long periods. Obviously, the internals of an engine are steel, aluminum, cast iron, and other metals. Each of these metals corrode when in contact with moisture. Over time, oil runs off of the internals, letting moisture get to bare metals. That corrosion may be washed in to the oil as a long idle engine is started. So you would then have iron oxide, Aluminum oxide, and some degree of moisture in the oil (at least until it gets up to temperature). Freeze thaw cycles can introduce lots of moisture to the crankcase, and therefore oil as well.
If you talk to a mechanic (not an entry level service tech at the oil change or tire specialist place), they will likely tell you to change your oil and filter at least annually, even if the manual doesn't tell you to do so. This is to help clean the above described contaminants out of the crankcase.
Today's engines are using synthetic oils. Manufacturers are designing engines to use synthetic oils because it has a lower viscosity, which means less resistance to moving parts and thus better fuel mileage. Secondly, most owners like the longer time between oil changes. There is some debate about what is better for longevity, but most are coming down on the side of synthetic oils being superior to conventional oil.
Any master mechanic will tell you that a vehicle left idle for long periods, especially if left outside or even on a dirt floor inside, will have as many if not more problems than the same vehicle that is regularly driven. My experience also confirms this.
FWIW,
Grant in Iowa
