Cherry drop leaf table repair
Barney in NJ
I ran across this table and thought I could use the wood, but upon closer inspection it seems that it is very nice and worth to be repaired.
The table is made of three solid panels, the center panel is 21in.
It has a crack down the center as well as several cracks on the side.
The drawer shows nice dovetails, Bottom panel has a t&g joint 3/4 down the depth that is almost open. The end is pinned. The pull looks like a replacement. At least it appears out of proportion.
The screws look partially handmade. They have a similar rust pattern. Hinges look handmade to me, too.
The leafs are kept up by a board that rotate out.
You can see one of the screws that holds the top.
The top was fixed to the apron with 4 large screws, and additionally with glued blocks. When I got the table, the blocks were already detached from the top, and the screws were somewhat lose. They are also slightly bent. All the cracks look very clean and recent. The center cut shows signs of previous attempt to glue it with hide glue.
Wouldn't this method of attachment cause the split? The screws have a bit of wiggle room, maybe 1/8in. Or maybe the addition of the blocks caused the split?
My plan is to glue the splits with hide glue. I might want to de-rust the screws and hinges (electrolysis). But how should I re-attach the top? Using the screws only? Enlarge the screw holes in the apron?
Or use the center glue block and add a screw? I would like to keep everything as original as possible.
Thanks for any advice.
