Air Compressor question
Terry Alexander
As luck would have it, both my 26 gal Cambell Hausfeld and 25 gal Craftsman oil compressors lost compression om yhe last 30-45 days. I just got in the new piston rings. You may or may not know, but,the piston rings are solid rubber.....not metal like on our cars. Before i re-assemble them, should i spray some silicon spray on my finger and just give them a little lubrication. I know they are supposed to be oil less compressors.....just don't know what would be best for them.
BTW...I did get almost 20 years use out of both of them. Hundreds maybe even over 1,000 hours of use out of both, so I'm not complaining. Parts for both just a little over $100.
As always, thanks in advance for your valued expertise and advise.
Terry Alexander in West Texas
Re: Air Compressor question
John in NM
Gotta watch silicone oil and plastics, I've had it dissolve stuff before.
If you want to lube it, try some standard air tool oil on the ring before you put it in, though even then I'd do some research before hand. If the manufacturer says oil-less, I would tend to follow their advice.
I used to have an ITT laboratory grade oil-less compressor. Had hard graphite rings. I only know because they cracked eventually and I replaced them with the newer version - graphite impregnated teflon rings. It was a kinda cool little compressor, but not really up to capacity for shop use.
not if you are sparaying finish
"should i spray some silicon spray on my finger and just give them a little lubrication"
a molecule of silicon oil will leave a dimple in lacquer.
and
it will prevent waterborne finishes from sticking all together.
Ralph Lipeles
I would definitely keep away from silicones and just follow the manufacturer's recommendations.
