Maple bench
Maple bench
Maple bench
Soft maple (hardest soft maple I've ever used) w/ cherry wedges for the legs.
My adaptation of a couple of benches that I saw in Williamsburg, VA.
Re: Maple bench
Re: Maple bench
BTW - I used an angled block cut at 12 degrees to drill the holes for the legs. All in all, it worked okay - but I still want to find a better way.
Re: Maple bench
Jack Guzman from Maine
Better way
I know I said this before but I will mention it just one more time. Using mirrors is an accurate way to drill angled tenon holes. The mirror is held in a groove in a block of wood at a slant so the reflection is directed up to the operator. You place a bevel set to the desired angle in line between the hole to be drilled and the mirror. You line up the drill so the side of the bit lines up with the edge of the bevel. You can set up a second mirror with a square in front of it to make sure you are perpendicular in the other direction.You get the angle of your hole exactly where you want it every time. I got my mirrors from Home Depot. They are 12"x12" mirror tiles. I got them in the flooring department. Nice table. It wouldn't take much to adapt that design to a settee.---Jack
Re: Maple bench
Re: Better way
I use that when I drill the seat blanks for my chairs. The sight lines on the bench are a bit shorter and don't allow me to comfortably use the mirror techniques on the ends of the bench.
Re: Maple bench
Clint Searl
Re: Maple bench
Clint Searl
I'm lucky to get three legs to the ground at the same time. Nice work.
Re: Maple bench
Re: Maple bench
Stuart Hough
Looks really nice, JL. I may have t inspect it when I visit my mother next. 8)
Re: Maple bench
nice legs and a suggestion
nice legs. Consider a slight chamfer around the top like Brain does with his pieces.
Re: Maple bench
Re: Maple bench
Very nice JL. That's what I always thought a table saw was for- displaying turnings. :)
Re: Maple bench
Re: Maple bench
What I learned was from Curtiss Buchannan. We drilled the holes by eye as close as possible and sized a little small. Then you use a spoon bit tapered reamer to size it for the taper on your legs. As you ream the hole you test fit the leg and bias the reamer one way or the other to change the angle as necessary. That way you sneak up on the perfect fit. He did show us the mirror trick to get the initial hole close.
Re: Maple bench
Done.
Used my low angle block plane w/ a chamfer guide.
Re: Maple bench
Leg leveling *LINK*
I put it on the table saw for a reason. It is one of my largest level surfaces. I put a level on the top and use small wedges under the legs to level the piece. I then use an Accuscribe to draw lines at a particular height on all the legs. I then cut off the ends of the legs w/ a Dozuki-me pull saw.
Accuscribe
Re: Maple bench
Re: Leg leveling
I too use my TS as a flat surface to check legs. I have a router mounted in the wing of the TS. I put a straight cutting bit in the router and raise it the thickness of a credit card. I have a bunch of "credit cards" I saved from hotel door keys and Lowe's merchant in store credit cards. I slide such a card against the router bit, leaving half the bit exposed and tape it in place. Then I slide long leg(s) of the table or bench over to the bit and cut off the thickness of the card. The card supports it as you cut off the last half. Allows you to nibble off the thickness of the card until things level up. Takes longer to explain it than to do it.
I call it the vertical jointer. The credit card serves the function of the outfeed table on the jointer.
If the legs are vertical, not inclined, I put an angled laminate trim in the router and cut a bevel on the bottom of the legs.
