Back to the Makita Chop Saw
I posted about the electric brake failing on my Makita Compound miter Chop saw. It started to run on after the switch was released and I thought the electric brake had failed. Made a sound like a slipping brake and it was cutting poorly. Tonight I figured out the bolt that holds the blade on had come loose and the blade would accelerate but would not stop instantly. The chiring scraping noise was the blade spinning on the shaft. I tightened the blade and it now works as it should. I believe the brake actually works a little too well and impacted the blade loose. Turns out that the blade being loose changes the sound and feel of the brake. Boy do I feel foolish.
