I've got a Wilton 4 x 10 woodworking vise I bought 55 years ago and it never failed me, til now. It has the rapid action feature where you rotate the handle counter-clockwise to extend and push it in where it should engage, mine doesn't engage. Sometimes all of a sudden it'l catch. very frustrating to say the least. I'm reluctant to remove it from the bench, afraid I don't have the balls to get it back on. Any idea on the repair for this?
There shuld be a Half-nut in a sort of cage on the screw underneath. It is probably caked up with sawdust and grease from years of use. The best way to clean it is to detach the vise, but if you can't handle the weight ( I'm sure it is very heavy, as my Columbian is) you might be able to get it loose by profusely spraying it with WD-40 and working a toothbrush in between the threads to clean out the caked up gunk. This will be a tediously slow job, and very hard on your back and shoulders as you lie down under the bench and reach up to the vise. When I restored my vise, it was SO much easier to take it off the bench and work on it, even with the weight factor. Good luck!
I agree with Stuart: it will be much easier to deal with the half-nut mechanism with the vise off the bench. Here's a tip for removing it. Clamp two boards firmly in the vise, one on either side of the screw mechanism with both boards touching the floor. Mark the boards along the bottom of the vise face so you can reposition them in the same configuration later. Unbolt the vise from the bench. The boards will support the weight once the vise is loose and make it easier to handle. You'll have to wrestle the vise onto the bench top, but that should be easy with the weight supported by the boards. Once there, you can remove the boards if necessary to service the half-nut mechanism. When you're done, replace and clamp the boards in the vise and reverse the process. This will still be a bit of a struggle, but the boards make it a lot easier than trying to manipulate the vise while supporting the weight by yourself. Good luck.
I just pulled it off the bench by extending it all the way out and nailing up a 2x 4 leg with a short 1 x 4 fastened to the top and bottom to make a support.....made it easy to remove and manage the weight. However, now that it's out the inside of the nut isn't caked up with any residue at all, seems clean as a whistle. The only thing I can figure out that is causing the problem is there is a i/2" plug that is loaded with a flat spring keeper and perhaps that has weakened so its not doing its job. That is the only movable part on the nut. The nut itself doesn't appear to be worn.
Wilton is still in business and they have a service department - at least their web site says they do. Why don't you give them a ring and see if they can help?
