Rift cut ash display cabinet
I finally have the display cabinet underway. The basic design is shown in Picture 1. It will be made from rift cut ash from slow growth trees so the grain lines are close together. One would think that from 300 bd ft of rift cut ash and 300 bdft of flat cut ash it would have been easy to pick matching lumber the yielded straight long pieces to frame the doors and side. It wasn’t easy getting the color and grain matching. I sorted through every bit of it to barely find acceptable lumber. Typically ash grows too fast here to get what I wanted. I wound up cutting the long pieces off the edge of an 8/4 plank.
Picrture 2 shows the parts for the upper part of the cabinet. I still have to prepare the top and bottom. The top will be dovetailed into the sides and the bottom inserted in a housed dovetail. I will likely veneer some plywood for the top and bottom to avoid cross grain issues.
Picture 3 shows cutting the vertical parts...all the same length. I do love my table saw sled for these operations.
Re: Rift cut ash display cabinet
That's going to be a beauty. I love rift sawn wood. I am wondering about the curve in the upper edges of the doors. Do you think the straight grain is going to clash with the curves? Any chance you can find a piece with curved grain? I'm not a good designer and I am probably over thinking this. As usual.
Brian Holcombe
I love rift sawn ash, and while I know fast growth makes a stronger ash tree I also prefer slow growing for visual appearance.
If I can throw a wrench into the works :D Why not a frame and panel top? Avoids cross grain issues...
answer to wrench in the works
The side is "frame and glass" and I will use bridle joints, well, because Krenov would have used bridle joints. I have no idea why he preferred bridle to M&T and I don't have a recollection why I chose to follow this path but that is where I am headed.
So, I need something to hold the sides together as well as square the cabinet. After some mulling of options I am, as we speak, veneering some Baltic Birch 3/4" plywood with rift ash veneer I just sawed. These two panels will be joined into the sides with dovetails much like a typical Period top might be joined to case sides. This panel will hold the case sides together while squaring it, provide a stop for the door, and a place to fasten the back to. Additionally, the top and bottom will wind up flat which is desirable. I don't anticipate any problem dovetailing into the long grain of the top and bottom rails. The Baltic birch is about like solid wood so I don't anticipate problems making the dovetails in it, though admittedly, the tails will not be as strong as they would be in typical construction. But I am confident they will be good enough.
Krenov tightly fitted the backs to his cabinets and glued them in place to provide a significant structural element. I will do the same.
I don't have your imagination and I am not imagining how I would do a frame and panel top. It must provide all the features enumerated above for the veneered top. How would you fasten the top to the sides?
I had considered frame and panel top and bottom fastened to the sides with housed dovetails, but then realized the socket would cut off the ends of the bridle joint. The joint would probably be strong enough to survive this assault, but the idea was objectionable.
Some years ago I had sawed a lot of rift ash. I used it for building our kitchen. But the trees from which it came either grew relatively fast or had a lot of heartwood. I used the sapwood- heartwood combinations to make some dandy book matched door panels in the kitchen. But of what remains it is largely too coarse grained for this small project. As a result I have had a nightmare choosing the lumber to make parts.
