Cutting wedges?
There has to be a better way....
How do y'all cut wedges? The sort you use for fox tenons? The sorts you use for other tenons? Anyone have a link to a decent wedge jig?
I am talking smaller, thinner wedges.
Cutting wedges?
Re: Cutting wedges?
Jack Guzman from Maine
I make alot of wedges. Spindles coming through chairback and arms. Leg tenons coming through chair seat. I take approx.2"thick chunks of maple or oak dried in my kiln.These are cutoffs from leg blanks riven out of a log. I use a knife edge and a mallet to rive these into useable widths. 5/16"for spindle tops.5/8" for leg tenons. Then I just split off 1/8" sections of this for my wedges. I have a block of hardwood that is cut in an L shape and clamp it in a vise. Using a sharp chisel I taper my wedges in this block of wood. I hope the picture helps you visualize this. I've tried all kinds of things and this is the best thing I could come up with.---Jack
Re: Cutting wedges?
John in NM
Easy, I have a jig made from a bit of 2x6 that I use with the bandsaw. I use it for door/window installation wedges and handle wedges.
You just square up three sides and cut the desired wedge shape (ie length and angle) out of one side. Easiest way to do that is to use a wedge against the fence to get the angle you want for the cutout in the jig.
I've cut some wedges much taller than the jig, like about 3x taller. But then my bandsaw tracks quite well.
Re: Cutting wedges?
Jim Dillon
JL, I also have used the bandsaw. Here, hopefully, are some pics:
Thanks
That looks like it will be the ticket.
Re: You're welcome.
Re: Thanks
TomD
I cut the end off a board that is planed to correct thickness. The end cut is the length of the wedge. I set the miter on my saw to half the wedge angle, then I run it through the saw to take the first bit off, once the end is cut to the mitre angle, I flip the board at every cut and get a finished wedge per cut. When the piece gets too short to hold, I can glue it to another piece and just keep cutting.
If the wedge material is super valuable I can cut it on a jeweler's saw blade, at 23 thou. But it would have to be dang valuable.
More often than not I use a chisel rig a bit like the one shown, same exact principle, I just grab some notched piece of wood, and use a long handled chisel.
Re: Cutting wedges?
William Duffield
Here is the jig I use.
It uses the table saw. Only one wedge is cut at a time. I just placed the other wedges back on the jig for the photograph to show the sequence of cuts. This one is permanently attached to a runner that goes in the miter slot, but if you needed a variety of angles on the wedges, you could attach it to a miter gauge instead. The block held down with the screw is adjustable to vary the width of the wedge. The large black pusher block is basically the same length as the end grain stock that the wedges are cut from. The stock (cherry in the picture) is flipped over after every cut. The first cut results in a wedge with half the angle. I don't cut anything with the square laying there, of course. It is just in the picture to illustrate the angle between the jig fence and the runner.
The only reason to make them on the table saw instead of the bandsaw is to get smoother surfaces for gluing. A similar jig would work on the bandsaw.
I use the wedges for making the salad forks in this picture:
Re: Clever!
Jim Dillon
William, that is a neat jig for cutting wedges and, as you say, could be easily adapted to use on the bandsaw. I also like Jack's "quieter" approach to cutting wedges. Thanks to you both for giving me some ideas. Jim
Edit: And what a great use for the wedges to reinforce the fork tines!
