Re: Lathe needs
TomD
I think you are better off getting a second hand deal on a real machine. For instance, up here the General, bigger lathe comes up for sale for as little as 1200 can. I owned the smaller version as my first lathe, after seeing Del Stubbs use it. Then I bought a Union Graduate bowl lathe, and a Conover, both of which I still own. In a lot of ways the Conover is the bomb, though my tool rest stand recently broke, and was never that good. I can fab up a good one. It can be stored in a few milk crates, or built into any size of monster you want. But hard to find. I think it is too bad that none of the Chinese sellers took over the Conover. But aside from the Conover, if you get a "real" lathe you will be able to sell it for what you paid for it, or nearly so, and have the pleasure of the use of a real lathe.
When you upgrade, normally you don't stay the same. Having the better machine may push you in the direction of more ambitious projects so what seems like a natural occasion for a 50% upgrade can end up being a stealth 75% upgrade need.
Lathes are the limiting factor in lathe work. Sure an expert can push the boundaries. As a non-expert I turned my first bowl on a sheet metal lathe diagonally placed on my table saw to use it's motor. But why would one want to. But the flip side to that is you need to call it quits at some point as the demands can be unreasonable. A 12/24" solid lathe with a decent motor is a good place to take a stand.
The US equivalent of this, that is 730 dollars. There is a general 160 for 500 dollars, though it isn't as nice a looking lathe.
http://www.kijiji.ca/v-power-tool/ottawa/general-260-wood-lathe/1213082791?enableSearchNavigationFlag=true
