Chop saw cut question?
I had an ancient chop saw for many years. Sometimes I used it to cut mitered corners on small boxes. It worked well. The saw got stolen in the great tool robbery. I bought the Makita Compound miter saw mentioned below. I tried to cut miters on some thin (3/16") walnut about 3" wide/tall. They were sloppy. I stood the pieces against the left/low fence. The cuts came out off vertical. I corrected them on the TS.
Trying to figure out what the problem was. Checked the blade for vertical. It is. I think the problem is the fence is low on that side to all the blade to angle off vertical and the pieces were not fully supported. Maybe I should have angled the saw the other way and use the right side/taller fence Or tipped the saw to 45 off vertical and laid the pieces flat on the rotating table. Or used an auxiliary fence.
Any suggestions/advice? (not used to the "compound" function.)
