I have a Makita LS1040F Compound Miter Saw. This is not a sliding saw, just a chop saw that will cut at compound angles. It has very few hours on it. Does it have a blade brake? The ancient Dewalt it replaced had one and the blade would snap to a stop. I thought this one did that also. Now it just slows to a stop. Sounds like the blade is grinding the brake. Has the brake failed or has my memory failed. I apparently have CRS.
I went to YouTube. Came up in Russian or something. Could not figure out why. Tried watching the video anyway. Got in a hurry and had to go to a meeting. Decided to ask here.
So the ad said it has an "electric brake". Mine apparently has quit working (the brake that is). Any Idea what to do next?
Almost all the brush type motors with Blades (CMS's, Electric Lawn mowers & Chain saws etc) use an "Electric Brake". They work (or at least used to with older equipment) due to the motor turning into a generator when rotating with the power off. The motor is normally shorted out by a set of NC contacts in the off / on switch that is in series with a resistor. The power generated is dissipated through the resistor. Another method used when the motor is not a brush type is that a capacitor is used instead of the resistor to provide DC (direct current) to the motor instead. When DC is fed to an AC motor it tries to lock the motor up.
I have worked on and rebuilt both types of equipment many years ago when I worked in a motor repair shop. Usually either the Switch is defective, the resistor opens up, or in the case of the capacitor type the cap is burned out.
In the case of my Dewalt saw, the on/off switch has quite a bit of travel between the contacts that power the motor and the contacts that brake the motor. I can release the switch slowly and the blade will coast, when I fully release the switch the brake will stop it very quickly.
i have the same chop saw , change the brushes that will fix it it is hard on brushes , if you look at them they will be ruff looking and not smooth , i change mine quite often also i let the switch slip off my finger also seams to help stop the blade
Thanks for the explanation Larry and the suggestion for new brushes Del. The ancient one I had "put a DC pulse" through the motor if I remember correctly. It worked for thirty years. This one has a very few hours on it, probably less than five of actual runtime. Surely less than a thousand starts and stops.
I am disapointed and struggling between the Mr. fix it side of my brain that wants everything to work perfectly and the Fagedaboutit part.
I wonder if continuing to use it is damaging it further?
Nope, it will not hurt the saw to run it without the "brake" function although it is a little less safe. Actually the saw parts will wear quite a bit faster, especially the brushes, when the brake is operative. The brake is simply a safety function so only you can determine if you need to repair it to stay safe.
