First, I appreciate your responses regarding what kind of epoxy to use on the handles. Just to recap, I am going to make knives for the men of the family for Christmas (getting an early start for a change
So, in anticipation of a "learning curve", if I screw up a handle, what is the method/process for removing the old handle (and epoxy) and starting anew?
As always, thanks in advance for your valued expertise and advise.
Heat and not a whole lot of it. Well under boiling if I recall. That might be your answer, submerge the handle in boiling water. The point is, not enough heat to ruin the temper in the knife will do it. If its not fully cured, alcohol like DNA will remove the residue and may help anyway.
No blanket answer for a temperature to release a knife handle. A lot of the handle materials will insulate the joint and I'm pretty sure it will take more than boiling water. I guess you know how to remove rivets, LOL.
You're going to need some very special purpose tools, whose distribution is strictly controlled by the knife makers' guild. The secret is you can find them at the Borg or Harbor Freight, usually with clear yellow plastic handles. These are usually a couple bucks apiece. You don't want to mistake one of them for Norm Abram's oxymoronic shahpchisel. Once you've removed enough of the scale to get down to the epoxy, you can start to melt it with a soldering iron, and then use the tools whose name shall not be mentioned to scrape off the rest of the epoxy. To keep the knife blade from getting too hot, a large heat sink clamped to the base of the blade is useful. I like the convenience and portability of the Wilton ATV.
One of the more interesting scale attachment methods I've seen started with rivets flanged below the surface of the scale, in a shallow mortise, and epoxy filling the space between the rivet and the scale. There is no chance of a non-desctructive removal of these.
you'll want to join a knife forum anyway, so start with this one.
It's a friendly, very helpful knife building forum where newbie questions are pounced on with enthusiasm. Lots of opinions, but everyone there started at the bottom.
Every answer you've received here is valid. If I were in your shoes I'd just pop the scale off with a shahpchisel and sand off the remaining epoxy. If it's riveted, too, then the sledding gets much harder. I've done both ways. You'll figure it out.
Terry Most epoxy that I've played with softens pretty easily with heat from a heat gun. Usually around 180 degrees but I know there are epoxies that take a lot more heat than that. Use a heat sink such a pair of vice grips with maybe some soft metal to protect the knife from the jaws. Then heat the handle from the tang end so you lessen the chance of changing the color of blade.
You could of course use a chisel at the glue joint and possibly pop them off. You will have to drill the peened over rivet out of course if you've gone that far.
