Any solid-surface experts around here?
A.J. Hamler
A.J. Hamler
Hi guys...
After more than 12 years of living in this house, I need to give the solid-surface countertops in our bathrooms a little TLC. The thing of it is, is that I don't really know how. There are two main things I want to accomplish.
First, I want to simply remove the extremely minor everyday abrasion it's acquired over the years, and bring it back to as close as the original shine as I can. As noted, this is very minor stuff here, just a general dullness mostly. Would auto rubbing compound do it, or would that be too much (or maybe not enough)?
Second, I have some minor scratching my wife caused with emery boards. She rests her fingertips on the counter while going to town with the emery board on her nails, which inevitably hits the countertop repeatedly. There's all these little V-shaped scratch patterns -- left side of fingernail, then right side -- all over the counter in the bathroom she uses most. These are not bad or even particularly deep scratches, but at the right angle when they catch the light you can see those V marks and I want them gone. What's the best way to deal with those -- same as above? Something more abrasive?
Thanks in advance.
A.J.
Re: Any solid-surface experts around here?
Not An Expert, But
Have repolished a Corian counter for a friend. Went to auto compounds (Mequire's). Used 3 grades on different cotton buffs, #2 fine cut, #7 Glaze and finish with # 9 Swirl Remover. They were pleased.
If, however, you've got deep scratches, I think you're going to have to get out the RO and, like any table top, work through the grit from 150 up through 800-1000 before you can start repolishing. I could, however, be wrong on this part ;)
Yikes, sounds like the opportunity to make for her a nice little wooden fingertip manicuring rest from a fancy piece of exotic wood!
That's Mirka Abralon
Dick Coers
Works like a dream. Sanding solid surface is like sanding a gloss finish. Start course enough to cut out the problems, then keep using finer grits till you get the sheen you want. To do a really pro job, you'll need to pull the faucets and drain if the sink is integral.
garthinsandiego
Check out the John Bridge tile and stone forum (http://www.johnbridge.com/vbulletin/index.php) Very helpful and a lot of good information.
thanks guys!
