Mortise marker question
Daughter (who has added several pieces of furniture to my to-do list) kindly gave me the Marples premium mortise marker , no doubt with the hope it would soon be employed on her wish list. It is nice. The head is fitted tight to the shaft which makes it easy to accurately adjust the length.
But it came with pins longer than I have ever seen on a mortise marker. They are 1/4" long. I have only ever owned used marking gauges and they had pins that barely extended above the wood bearing surface.
As received, the conical pointed pins made nice lines with the grain, and ragged lines across the grain. I ground one side of the pins slightly to flatten the point and that improved cross grain marking. But I still have these long pins. What to do, if anything else? I have not used it enough to determine if the long pins are a problem or not.
Apparently Marples makes several grades of some tools. The top grade seems to be marked "Trial".
