sasafrass
sasafrass
sasafrass
ben d.
I have a friend that has a band saw mill and he has purchased 2 logs of Sasafrass that is at least 2 ft. in dia. and can get 4 to 5, 8 ft. cuts from each log.
My question is he is going to saw it up into 1" lumber and asked me what could be made from it that would make a nice piece of something. I have no idea as I believe it is a soft wood.
Any thoughts good or bad.
ben d.
Re: sasafrass
Re: sasafrass
John in NM
Its not a softwood, but a deciduous tree in the laurel family.
No idea of stability and such, but it's nice enough wood. Looks a bit like ash with toned down grain IIRC.
Friend of mine used to use a lot of it for cabinets and paneling as he could get it cheaply from a buddy with a sawmill in NC or some such place.
Re: sasafrass
Re: sasafrass
Mike van pelt
I have built several pieces from sasafrass It works very well and a beautiful wood. I use it for building country style furniture.
Re: sasafrass
Re: sasafrass
Open pored, smells yummy (root beerish), works well. Consider quarter sawing to increase stability. A southern tree will have larger growth rings, hence more "soft" summer wood grain, hence more seasonal movement. Scraps make great fire starter due to the oil content.
Re: sasafrass
Re: sasafrass
That is a big sassafras, at least for where I live. I had a one die and taken down recently - it is no bigger than 18" at the base and it is a big one and solid inside. Most sassafras around that I've run into is bigger than that is hollow in the middle.
Sassafras is wonderful wood. Good for musical instruments (a thin board it rings a little instead of thudding) It smells great while working, which doesn't mean much. It is ring porous, it looks somewhat like ash but a different color, can be sanded and finished to a luster.
Sassafras is also a very stable wood, at least in my experience. It warps less and cracks less than a lot of woods while drying. I cut a lot of sassafras into woodturning blanks, some as big as I can, and none has cracked yet.
I would suggest he cut some chunks to sell to woodturners if he wants to market some that way. Here are some typical blocks I cut on my sawmill for a friend for making bowls:
I've made a lot of things from sassafras at the lathe: music boxes, bowls, various spindles, Christmas ornaments, etc.
4/4 lumber is nice, but if he cuts and dries some 2", 3", and 4" slabs they can be sliced up later into blanks to make bowls or ripped into turning squares for spindle work. That's what I often do with my sawmill - I air dry thick planks of cherry, walnut, cedar, and more and cut them up later into turning blanks.
He might check with specialty wood dealers in his area who cater to woodturners to see if they are interested in wholesaling some. Also, some Woodcraft stores look for local woods to sell.
Re: sasafrass
It also has great rot resistance
Keith Newton
It's also a good carving wood. Back in the early nineties, I carved the presidential seal for a replica of the Resolute Desk in the WhiteHouse. The original was probably Chestnut. My friend that got the commission, thought it was probably Oak when he ask me to help, but I couldn't see any evidence of medullary rays in the photos, and I wasn't looking forward to carving Oak, so I suggested Sassafras, which was wonderful to carve.
I wouldn't saw it all one inch if it were me.
Re: sasafrass
Yup, It would be a shame to only saw 4/4
Dick Coers
Very stable, almost no sapwood, incredibly even color across the whole log. At least that is my experience. 13.5" diameter x 6" tall. Turned this bowl about 20 years ago. So consider this an aged color.
Re: sasafrass
It is a bequtiful wood- suggestions
1. there is a lot of waste in 8' lumber. If you have the storage length cut logs 12'.
2. Rift and quartered lumber is exceptional. I would saw the logs in a way to maximize rift and quartered grain lumber.
We sold sassafras mainly to Dulcimer makers. It made a gorgeous back for the instrument.
When you work it the shop will smell like A&W root beer.
Re: sasafrass
Re: sasafrass
Joe Mohnike
I turned some if it, while it was still had about a 10-12% moisture content. When I would stop the lathe to inspect the turning, the bowl sounded like it had Rice Krispies in it. You could hear the newly exposed cells breaking, lasted for about 3 min. Nice wood to turn and finish.
Re: sasafrass
Re: sasafrass
Blue
Sassafras makes a good walkin' cane.
Re: sasafrass
Clint Searl
Our resident pileateds love it
Clint Searl
Re: sasafrass
Re: Our resident pileateds love it
ben d.
Thanks to everyone for the reply's
ben d.
