Exterior Panel Door Repair
Joe Pack
I would like to repair an exterior wood panel garage "man" door. The door is an original from a 1970's vintage house. The concrete floor under the door has raised a bit over time, and the door seems to swell somewhat with moisture from time to time. The joints between the rails and stiles on the hinged side of the door have opened up as a result of binding at the bottom (hinge side) and the door being forced open/closed over time. There appears to be no rot in the wood, only joints failing. (This may or may not be related to rot inside, but I won't know until I take the door off and start work.)
My plan is to remove the door, gently open the joints a bit farther, inject a good exterior glue (Titebond II or Titebond III, or maybe a thin epoxy?) into the joints, then clamp everything back together. Depending on wood condition, I could also reinforce with pocket screws on the face and/or on the bottom edge.
After making the door solid again, I will sand down the bottom edge to fit into the tight fit caused by the concrete floor moving, then seal the door, particularly the edges, with a quality sealer that will reduce expansion/contraction of the wood itself.
This sounds simple, but I am experienced enough to know better! So, where am I messing up? What suggestions do you have re: glues, reinforcement, etc.??? If I can pull this off, I will be a hero to my daughter-in-law, so your advice is truly welcome!
Hope all had a very merry Christmas.
Re: Exterior Panel Door Repair
Dick Coers
If that's the original door, rot will be a real possibility. I'd use epoxy if you are not going to clean up the old glue in the joinery.
