Belt Dressing Question/Air Compressor
My Sears Air compressor lives in a shed behind the shop. The belt has begun to chirp and slip. I have changed the oil in the compressor and just tightened the belt. Would it be a good idea to add some belt dressing? The compressor is quite old and it may be time for a new belt, but I am not anxious to change it. Its labeled BT 31 49016 and what appears to be the same belt is on Amazon for about $10, but I would rather buy one locally if I can. Any suggestions on where to look? Auto Parts place? Any chance this is related to cold weather?
Re: Belt Dressing Question/Air Compressor
The auto parts stores around here (Napa, Advance, etc) carry almost any kind of belt. If the numbers are still on the belt they can usually look them up, otherwise best to take the belt with you.
Replace the belt
Dick Coers
My wife came back into the house one day after getting ready to leave for work. "Something is running in the garage, and it smells". Rubber dust was around the motor, one belt was broken, and the other one had a chunk of rubber missing. No idea how long that motor had run, maybe all night.
Pete in Holland MI
Your belt sides are wearing, and it's settling down into the groove of the pulley. V-belts should never touch the bottom of the groove. V-belts get their traction by swelling as they bend around the radius of the pulley. Once they bottom out, they can't swell properly. You can tighten it all you want after that and it'll still slip.
Buy a new belt.
Definitely replace
John in NM
The belt I'm seeing on Amazon is a serpentine belt rather than a V-belt. May be hard to find, but if you can get one locally it will be either at Napa or a bearing supplier (they usually carry belts & stuff).
Belt dressing is like septic tank treatment - it does nothing but transfer your $$$ to the guy peddling an easy fix :D
Replace
You'll want to clean those pulleys as well. As mentioned, forget the dressing thing.
FWIW, I've used red Fenner drives (link belts) on most of my belt-driven machines, including the compressor. They have done well, and were easy to install. Just make sure you have the little arrows pointing in the direction of rotation.
PS: I've seen comments that link belts make more noise, but I haven't noticed any increase in volume.
Thanks, new belt ordered, here in a day or two.
