Sort of OT Pond Boats -- Sources?
Gary Smyth
I have recently inherited a 1930's mid size (26"l x 6"w x 48"h) wooden sailing pond boat configured similarly to what is pictured above. It has not arrived yet and I have only a faxed picture but I'm certain that it will need some major refinishing, replacing reduced size model boat fittings, and perhaps new sails.
I've done some searching in modelling magazines, books, and online, and what old catalogs I can find. Looked at dozens of pictures and drawings. Water safe model boat hardware is frustratingly difficult to find as are tapered wood masts (40"), and booms and bow sprints. Small hooks and eyes, and line found in stores are typically too large.
I'm looking for sources of water model boat hardware. Anyone have the name of a hobby group, model boat source they can suggest? I'll be pleased to take all supplied. If I've found it previously, no harm .
Re: Sort of OT Pond Boats -- Sources?
Re: Sort of OT  Pond Boats -- Sources? *LINK*
These people have an awful lot of model parts and supplies. I could buy something from almost every page in their catalog if money wasn't a problem.
http://www.micromark.com/
Mark Nowicki
It would help if you knew the scale.
There are a lot of fittings for the 1:96 scale (museum scale)
http://www.loyalhannadockyard.com/APPENDIX.htm
Model building is popular in the UK:
http://www.cornwallmodelboats.co.uk/acatalog/billing_boats_mast_fittings.html
http://www.bluejacketinc.com/fittings/
"Ship modelling from scratch" by Edwin B Leaf is an excellent book if you want to go the do-it-yourself route. Hints on making fittings, sails and rigging using common tools, materials and woodworking techniques. You probably have the tools and the materials.
http://www.goodreads.com/book/show/559349.Ship_Modeling_from_Scratch
Update.  What would you do?
Gary Smyth
This morning the pond boat arrived. Some speculation from The Chautauqua Institution grounds and built ? but used (and decorated) by generations of kids starting in the in the 1920's.
Question is, should I update it to be a rerigged and "traditional" but updated water boat, or try to restore it to the "original" look, and make or find gear appropriate to the era. Either way it's work, and with a simple mast ring costing near $1 each, a time and expensive proposition. The boat is hollow and not solid as I imagined. It appears to be bent plank on frame and secured with wood dowel pins. The lead keel weight is solid and an estimated four or five pounds. Several of the rigging anchors and stays are absent and the mast, boom, bow sprint, and spreader needs replacing, rerigged and/or splicing. The existing sail is torn about 3/4" and one is missing completely. The rudder assembly also needs redone and this applies if static display or water bound. The sources provided above earlier have been contacted or soon will be. (I have MicroMark and Bluejacket). Many of the others may be in England, Italy, or Germany but much or the hardware is there!
This is a nice dilemma. If the darn thing was not nearing 100 years old I would modernize it. But it would be terrific also if kept old with new but appropriate and weathered hardware.
Display or float? what would you do? Thanks to John and Mark. If additional sources, keep em coming.
Happy holidays to all.
Re: Update.  What would you do?
Dale Stansbery
Those old pond boats can be quite collectible and pricey. I assume yours would be at the higher end due to it's age and construction. Before doing too much to it, you may want to research it's value, then decide on your course of action. I have a newer one that is of solid construction, probably not too valuable but a great display piece anyway.
Mark Nowicki
www.modelyachtfittings.com
Only you can answer the time and money and "do I want another hobby"
question.
Personally, I would restore to display.
