WAY OT - need help on boat lift
Tim Greif - West of Chicago
Not wood related at all. I bought a 25 year old all aluminum boat lift and floated it down to my river house. The lift has adjustable legs that slide up inside the vertical frame columns. Lady I bought it from had it in very shallow water with the legs all the way up inside the frame. I can't budge the legs. We beat on the bottom foot pads of the legs and all we did was break the weld that attaches the pad to the inside leg member. The inner legs are 36" up into the outer legs. I've removed the canopy and its vertical legs that slide down inside the outer legs to get access to the inner pieces. The pic shows what I'm talking about. I contacted a dealer and they suggested fabricating a steel piece the same dimensions as the inner member and using that to beat the inner leg out. He said that in his experience, that it's unlikely that aluminum corrosion has fused the pieces together, but rather 25 years of river silt has packed itself into the void between the members and locked them together mechanically. I'm wondering if some kind of percussion tool exists that would help drive this thing out. I either need to raise it all up over 3 feet to allow the legs to drive out or flop it on its side to do the same. I can get a pressure washer wand in there, but it probably won't penetrate enough of the 36" of contact to really do much, but I'll try that as well.
Any ideas?
Re: WAY OT - need help on boat lift
Re: WAY OT - need help on boat lift *LINK*
Dick Coers
Harbor Freight sells a long reach impact scraper. You'd probably need to make a blunt end for it, and maybe a plug to fit the aluminum.
Also thinking about slitting the aluminum with a cutoff wheel, knock out the inner piece, then have the aluminum welded back up.
And then there are chipping hammers that you could rent. I bought a pneumatic one from Harbor Frieght years ago, they don't see them any more. I think you can get rotary demolition hammers that will take a blunt end for hammering.
http://www.harborfreight.com/air-tools/specialty-air-tools/42-in-long-reach-air-scraper-62687.html
I don't know where to get one, but I've seen a percussion device in operation. When I worked at an industrial piping company they heated big pipe red hot and bent it around mandrels into various shapes. (This pipe might be 18" in diameter, 2" wall, 40' long.) To keep it from collapsing when bending they stood it up on end and packed it with sand. A hydraulic percussion hammer was moved up the pipe pounding the outside for hours knocking compacting the sand. Very loud!
I wonder if, assuming the space is indeed packed with sediment, if you could submerge each leg in water (drum?) then hammer the outside and unpack the sediment, working from the bottom. A jack hammer? Ultrasonics might also work but seems like it would take massive transducers and a monster of a frequency generator!
Or how about drilling a series of holes up the side of the outer tube to direct the pressure washer stream? (then weld to plug)
Worst case, cut up two sides of the outer tube then horizontally to expose the inside, wash, remove the inner, then reweld? Oops, I just read the other response and see the same suggestion! Not an unreasonable idea, especially if you can weld aluminum yourself. At some point, though, it might be cheaper and quicker to just cut away and rebuild the bottom few feet of legs with new stock.
Mark Hennebury
I would drill and tap a hole in the top of the outside leg, and screw the pressure washer hose into it and blast the water inside the legs and see if you can force it out like a hydraulic cylinder. If that doesn't work use a hydraulic lever hand pump to pump water into it.
Bill Turpin in WNC mountains
Buy a gallon of WD40. Mix it well. Soak the years of mud thru some small holes drilled thru outside tube. Set drill depth carefully to NOT create interference burrs between tubes. Heat the outside tube with a torch to make it expand. If inside tube is open flow water down it to shrink it.
John McGaw
Path of least resistance: cut the bottoms off and have someone weld on new leg stock and feet, perhaps with a bit of external reinforcement over the welds and a new pair of stretchers and some gussets. Having the doubled leg stock up above is no bad thing and nobody but you will know it exists. Even heavy aluminum stock is not that expensive and this solution is a known quantity and not subject to luck. Just my $0.02 of course...
Ralph Lipeles
I like your idea but would use a vegetable oil, the type used for cooking, so that oil residue will not pollute the lake.
Wow Dick - I have one of those
I forgot I already have one of those long handle pneumatic chisels from HF. I used it to scrape adhesive and residue off a concrete floor that had been carpeted. worked well. Now I just need to see if I can adapt some sort of plate to the end to act as a battering ram type of jack hammer against the inner tube. Thanks for the advice.
Thanks all....
I now have a few things to try when spring arrives. I love the collective knowledge here at Woodcentral. Always amazes me.
