heatpump and micro climates
Ken Kimura
Last month my 20 plus year heat pump was replaced. The blower motor sized. The outside unit was located at the southeast corner of my house. I replaced this with an inverter-driven compressor technology unit placed in a south central facing part of the house where my line set was at it's shortest to a new inside heat exchanger.
I've notice a large temperature difference from the north side of my house and the south. The other day the north side registered 18 degrees and the south side was 27 degrees. Had I placed the heat pump on my north side, would I be paying more on my annual cost of heat?
On a side note, the contractor put a mini split in my garage/shop. My new system has been operational less than a month. It freed up two 220 circuits. My old system had a total of three 220 circuits. The heat seems more even - no more cold spots. I'm astonished the heat pump extracts head down to -13 degrees when my old system had to use strip heat when the outside air was around 34 degrees. Best part, the cost represents 3% of my home insurance structure valuation.
