new air cleaner installed
Joseph Mulherin
Just had my grandson screw in the angle irons which will hold the air cleaner rigid to the rafters. Now all I have to do is the electrical and it will be finished before Xmas.....present for myself.
Re: new air cleaner installed
and . .
a present for those who'd like to keep you around longer. ;)
Re: and . .
Joseph Mulherin
Thank you, Mark. I want to get back into the shop after that robbery I had last year and start working on my version of the Sam Maloof rocking chairs and the lounge rocker he made his last year.
Ralph Lipeles
My air cleaner is home made. When I installed it, vibration noise was transmitted through the ceiling structure. So I put eye screws in the ceiling and on the air cleaner and suspended the air cleaner on 4 short chains. That did the trick. Hopefully you won't have to do that.
Joseph Mulherin
Yes, Ralph, I do have the large screw eyes I can reinstall and also the chains to suspend the unit.....probably the best anyway
Joseph Mulherin
Wife said for me to find an electrician to finish up with the hook-up......he will be coming tomorrow morning and finish the job for me. I just do not feel comfortable working around electrical components.
jessecloud
Good decision. If you don't feel comfortable with something, don't take a chance. Life is too short already.
Air Cleaner Vibration
The chain will still transfer some noise. Reinforced rubber straps or spring links
might be better.
Re: Air Cleaner Vibration
Mark is right.
But, be careful with rubber straps. Be sure they are reinforced or have a backup loose chain beside them. Over time the rubber dry rota and fails. It does not get that cold in your shop, but I have had people tell me that in really cold climates, they don't use bungee cords, because they freeze and are brittle.
And, good move on the electrical. Don't do it if you are not comfortable. Pretty good general rule.
Could you please tell my wife I'm not comfortable with doing laundry? Of course, my life might be even shorter then.
Joseph Mulherin
called two electricians....they said they were very busy this time of year. So, I am going to install thye romex myself using cable straps on the rafters and then maybe one of those electricians will call and decide they can do the job. Job entails installing four(4) single pole switches and a timer. I just do not feel comfortable working electricity......will leave that to the pros.
I wish I lived near - I'd be tempted to sneak over and wire it tonight. I'm only an electrician when I'm in Mexico (ha!), but I've been wiring so long it hurts to think about it, my own shops, houses. farm...
If you run the romex, be sure to leave enough slack at the ends, probably about a foot or two more than you think you need. A few feet of cable is a lot cheaper than running the entire length again.
Also, be advised that some electricians may not agree to wire cable they did not run themselves. Maybe ask one first?
Joseph Mulherin
Thought I would try to send the plans and specs to the board so you woodworkers can see what it is that I built and installed.
https://www.pinterest.com/pin/416512665515938495/
The bottom board slides in dados to access the filters which are installed vertically from the floor. Three inlets and two outlets plus a cushion padding on the inlet side to catch the most heavy dust.
