200+ woodworking book reviews
OT-My wiper fluid pump stopped
tom
Today I noticed that I was out of windshield wiper fluid on my 2011 Ford F150. Filled it up and nothing! There is nothing being pumped. I checked the manual and there is no listing for a fuse.
Thoughts would be great!!
Re: OT-My wiper fluid pump stopped
Could be electrical, broken pump, broken hose, or a clog in the tank, line or nozzle. A clog can be ice this time of the year in cold parts of the country if plain water was added to the tank at some point.
This is how I might approach debugging:
Do you hear the pump trying to work?
If no, problem could be electrical: switch, wires, pump. Check for voltage at pump.
If there is voltage, try again and watch.
Is washer fluid running on the ground?
If yes, hose may be broken or disconnected.
If no, disconnect hose at nozzle, try again.
Does fluid come out of hose?
If yes, probably clog in nozzle.
If no, possible clog in hose, disconnect hose at pump, try again.
Does fluid come directly out of pump?
If yes, clear or replace hose.
If no, pump possibly bad.
If pump runs but pumps no fluid there is also a chance of debris clogging bottom of tank or the hose leading to the pump. I would check that fluid was actually getting to the pump. Unfortunately, vehicles today are so designed so tight it is not always easy to get to these things.
Bruce, a MN Galoot
Windshield washer fluid can freeze, too, unless it's rated for cold weather. Then it's good for something like -25F. This weekend, that might not be enough. >(
I'm not a car guy or a Ford guy, but I can't believe there not a fuse protecting that and probably a relay. I'm just saying.
Thomas E Norton
Yep, cold!! But we get a reprieve on Saturday it will be 48F. As for a fuse, It surprised me that in the fuse chart it is not listed.
Thanks for the replies!
tom
Fixed!! Got a new pump,figured out via You Tube how access the old one, drained the reservoir, installed new pump.. Voila!!
