Failing sanding belts Question?????
A few years ago I stopped at a Abrasives store/manufacturer who happens to be about fifteen miles from my house. I had them make up what I thought was a lifetime supply of 4 X 24 sanding belts. I have not used as many as I thought I would so I have about 80 percent of them still on the shelf. Recently I got out the sander and put a fresh belt on it and tried to sand something. The belt failed Instantly. Tried another, and another. They all failed upon contact with the surface. Most of them shredded themselves running through the sander.
Apparently these belts have a shelf life. These are the reversible ones that have the nylon or fiberglass reinforced tape joint. Should I be offended? Did I save them to death? should I take them back? I bought them wholesale, so they were less than retail, but not cheap. I assume the other fifty or so will fail just as dramatically.
I have some of the old single direction ones left from Sears that are worn out and probably 25 years old. My packrat gene forced me to save them. They are pretty much useless but they will still run.
