Does anyone wear a headlamp?
Bruce Mack
I know--geekwear, but my wife gave me one 2 years ago. I recently wore it for the first time and found it excellent in illuminating the innards of a model house I am building, as I was reinforcing joints. Could also be used when you are trying to adjust stops on the inside of a contractor's saw. Sometimes just good shop lighting is not enough.
Re: Does anyone wear a headlamp?
Ralph Lipeles
I use it when I need something from the barn in a section that does not have electricity. I also use it when something must be done in the low sections of my attic where I must crawl on my belly to get where I am going.
Work great during power outages.
yes always....
...when traveling to deer stand before daylight. I use the red setting.
My shop is sufficiently lit that a headlamp is not needed there.
Re: Who needs a headlamp?
William Duffield
I used to wear one, but the light wasn't bright enough, it ate batteries like popcorn, and the elastic and velcro straps lost their stretch, and it would slip down over an eye so I would look like a Borg assimilant. I have plenty of bright area and work lights in the shop. Most of my work lights are portable and can be attached to a quick-grip or hand screw or tripod or dropped in a doghole. I can clip supplemental rechargeable cordless hand tool batteries to one of my work lights. I usually carry one or more tactical CREE LED flashlights with rechargeable batteries either on my person, in my backpack or in my tool tote. For dire emergencies, I always carry a weatherproof single AA-cell LED flashlight in my pants pocket that I can hold in my teeth.
Often
I use a 6-LED head piece than runs on 2 AAs. Don't need it in the shop, but useful when walking the pooch at night or doing stuff in basement or attic areas short on lighting.
I have used about 6 head lights over the years. Most or all of them were EverReady brand I bought at the borg. When flipping houses and crawling through attics and crawl spaces they are very handy. One thing I don't like is the ones that have about five functions. One light, two lights, all three lights, Red lights or whatever. These require you to cycle through the five settings to turn it off and on. It just wears out the switch. And its an aggravation. I am an Off and On kind of guy. Buy a simple one, unless you really like clicking and clicking. My experience was that battery life was excellent, but maybe its because I wore the switch out trying to save the battery.
Only at work....
John in NM
Standard gear when stuff breaks in the middle of the night and I come over to fix it. Never yet needed one in the workshop though.
jessecloud
Only in the hopefully rare cases where I have to crawl under something and its one hand for the fastener, one hand for the driver and one more for the light - oops. Yeah, the driver may have a light on it, but the headlamp is much better for looking around and trying to find that darn spot that needs the screw....
I have a good one with AA or AAA batteries, two brightness levels for white, plus red and green. The batteries are in a separate little box on the back of the strap. They have lasted for years so far.
I use it a lot around the farm when I need both hands free, such as when moving horses at night. Sometimes use the red light. I haven't figured out a use for the green.
One thing I discovered when caving: when using a headlamp where the ground is rough the light from near your eyes hides the shadows which let you judge the surface. A hand-held light is much better.
Bart Goldberg
Bart Goldberg
Yes, all the time. I use it often at night when I need a flashlight and the use of both hands. I use it when smoking meat at night.
Yes--sometimes even for woodworking
Henry Higginbotham
Long ago I bought a Petzl Tikka LED. It didn't put out a lot of light by today's standards, but was utterly reliable and got a lot of use. Today, I use a Princeton Tec Remix, which is a big improvement. I've used it following a line on the bandsaw and sometimes when using a pull-saw to fit something, but it's mostly used for working on machinery, routing wiring under a table, and, especially, for electrical wiring. I wouldn't be without it.
Today.
Virgil Johnson
Installing a light fixture. In combination with my top bifocal eyeglasses.
Bob Entwisle in NJ
I just picked up a cheap one from amazon. It's something that I've wanted to try for a while now. It seems I'm always crawling into or under something and need two hands free and holding a flashlight in my mouth is getting old :b Early trials with it indicate that it will be useful, providing I can remember where it is when i need it.
Bob in NJ
Only when caving.
You do.
Virgil Johnson
Maybe. Today's LED headlamps last 50+ hours on 3 AAA batteries. I have Black Diamond "Spot" model (around 35 bucks) which is very light and has multiple settings. Spot/wide and has a dimmer. Light years ahead of the old models.
I use them a LOT *LINK*
Keith Newton
I'm out in the woods after dark and before daybreak probably half of the weekends of the year. My all-time favorite was a Fenix brand that was really light and small, but really had a nice tight spot ~ $75. It used 4 AA in a pack on the back of the strap. Somehow that compartment broke, so I dropped back to a cheap one that had the big lens with two smaller floods on each side. It was uncomfortable and heavy enough that gravity would pull it off if I ducked under low limbs. The rubber battery compartment door would pop open loosing the battery connection. A few weeks ago I was dragging a big buck out of a thicket, gun in left hand, antlers in right, ducked a limb, light fell, everything went dark. I always try to keep a DeWalt 12v work light in my pack, but it got left in the truck the night before, so my phone was my only backup light. I was at least 1/2 mile into a pretty remote area, with one small creek crossing. I managed to find the batteries, and install them by feel. I ordered 3 more headlamps that weekend.
Of the three I recently bought, here is a link to the best of these moderately priced ones. It has a very bright LED, and a push pull lens for flood or spot, and uses 2 Li-ion 18650 batteries.
This will make a good stocking stuffer even if you don't do a lot of outdoor after dark activities. These batteries hold their charge better than the older technology and it comes with a car charger, so if your in an area where power to your home can be lost for long periods, this is would be great for your emergency. Less than $20, but better than what you could buy for ten times that much just five years ago.
https://www.amazon.com/dp/B01JGHIIVK?psc=1
Re:Resistance is futile!
William Duffield
Now, that's kewl! I like the idea of no elastic, and especially the rechargeable LiIon batteries. I think you've solved a lot of my Santa Claus issues. If it's reliable, Virgil just might be right.
Curiously, I've heard that there are some states where it's against the law to have a headlight and a rifle in the same vehicle.
Lighting
You obviously don't know Jack.
I've had any number of deer in the headlight. Got two of them too!
:D
Keith Newton
I'm not exactly sure about the law, but I think it says you can't be shining it out into the woods from your car, with a gun handy, but it may not even require the gun. However, I know the wardens in my area, and they know I'm a law abiding nature photographer, and not likely to hassle me.
You ought to give one a try. The sliding lense focus is so sharp that when it's zoomed out for a tight spot, it actually is a square enlargement of the LED.
The only thing that worries me, is im not sure how hot it might get, if it gets turned on in my pack. Not that the LED produces heat, but that many photons concentrated on a tight spot, would be like I used to use a magnifying glass focusing sunlight on an ants nest, and fry them as fast as they came out. I'd rather that on off switch was smaller, and tucked into a corner.
William Duffield
I carry an XML-T6 in my pocket (and in my teeth :) ). I suspect it has the same LED, focusing mechanism and battery. I've accidentally turned it on more than once, and never burnt myself or set my pants on fire.
I've put more than one of your recommended headlights in my Amazon shopping cart.
