sanding wood
sanding wood
sanding wood
Krystal
I have been trying to sand my kids dresser and the paint just doesn't want to come off. I think its because it was spay painted (?) can I just sand this down to thin it out and killz it or does it really need to be sanded down to the wood? I am new to this so I am learning as I go. Also for anyone who would like a good laugh, I decided it would be fine to just sand this thing down in my kitchen....I have quickly learned this was not such a good idea after all....blue powder is covering every dang surface, Huge mess
Re: sanding wood
Re: sanding wood
I am 90% sure you can Kilz it and keep on going. I personally like the Original Kilz, the kind that stinks until it cures. I have used it many times, but on walls to hide stains and it seems to me the original works better than the water based stuff.
You can also use Zinzer 123 Or Bullseye SealCoat shellac in a rattle can or it can be brushed. Be sure to buy the version that is Dewaxed. This is a clear finish, but the work is that shellac stick to everything and everything stick to shellac. The dewaxed shellac will serve as a barrier coat to prevent your new finish reacting with your old finish. Mix the wrong finishes and you can get a bad reaction, can act like paintstripper, may never dry, or may not stick.
There's a reasonable chance you can paint your new paint directly without the Seal Coat or Kilz. Check with the paint store for recommendations. And, test on an inconspicuous spot and let it thoroughly dry.
Kilz and 123 have "high" solids and do a nice job of filling scratched and tiny imperfections. Can be sanded very smooth. (But then you get White snow)
And yes, BTDT when it come to sanding inside the house. My shop looks like a bad snow storm in spite of running dust collection and an air scrubber. I tapped a wire above my lathe yesterday and what seemed like a pound fell off. Time to get the leaf blower out. I try to keep the shop cooler than the house. Its in the basement. The theory was that there would not be any drafts to carry the dust upstairs. Helps, but not 100%. You can use a box fan with a furnace filter taped to it to make a cheap and easy ambient air cleaner and it will help, but not 100%.
Re: sanding wood
A paint store is your friend
What works depends on what paint you intend to use. In any case there is no need to more than scuff sand the paint you have on the dresser. A sealer coat may or may not be needed.
I am fond of old fashioned oil based paints. They flow out smoothly when using a good brush and they will stick to whatever paint you have on the dresser already once this paint is lightly sanded. I am about to try a product new to me from Benjamin Moore called "Advantage". It is water based but it is supposed to flow out smoothly and not leave brush marks. The store personnel can supply application advice.
Re: sanding wood
Re: sanding wood
Jim Dillon
Krystal, the newer paints are really, really good from a coverage and drip proof standpoint. It sounds like you have scuff sanded for sure and maybe even done better than that based on the size of the dust cloud in your kitchen :). If you have some Kilz, great. If not, and given the intended users, several coats of a good quality paint should do just fine. Despite claims to the contrary, I have always found that a second coat really brings out the true color of the paint and am not reluctant to sometimes add a third coat. It is always a good idea to wear a dust mask when sanding but you can save that refinement (if one was not used) for the next project - done outdoors! Good luck. Jim
Re: sanding wood
Re: sanding wood
don stephan
Perhaps you could take one of the drawers with you to a Sherwin Williams, PPG, or other paint store used by full time painters.
