daughter has requested an iPAD stand
Has anyone made a spiffy looking iPAD stand or seen an example?
A slot cut in some 6/4 walnut just doesn't seem nice enough. But, then, I am design challenged to come up with something.
Re: daughter has requested an iPAD stand
Chuck Kettler
I will email an image of one my spousal unit has for your inspiration.
All wood and pretty is nice but for function, I have never used one better than this. There are a bunch of suppliers, they all look the same.
https://www.amazon.com/AmazonBasics-IPM-TAB1-AMZ-Adjustable-Tablet-Stand/dp/B006ZT4VA0
Compact, folds up, adjustable for a wide variety of tablets, phones, etc. I use one to photograph turned plates and platters. Padded where it needs it. All joints have spring-loaded detents for adjustment without possibly slipping
If I wanted a pretty wooden one I would probably try to take one of these apart and reuse the joints.
William Duffield
Clamcase makes combination cases, stands and keyboards. They provide the most important functions missing from tablets, in particular the keyboard.
If I were to make one, I'd start by calling Mario Rodriguez at the Philadelphia Furniture Workshop and find out when he was going to teach another class on the Jefferson Writing Desk. If that won't do, either due to timing or expense, I'd go look up the Lon Schleining article on building that desk in the FWW archives.
Larry Barrett
I made a mini-Roubo bookstand a few years ago. It has been appropriated and is now in use as an iPhone stand. It is a fun project and always gets an 'how did you do that' when examined.
Jack Guzman from Maine
The Woodwright has a video on how to do that. It has a few simple steps. Fairly easy to execute.---Jack
John Veerkamp
I used a really nice block of walnut burl. overall finished size is about 2 2/12X 3 x 6. I cut two slots at about 60 degrees 5/16 wide 3/4 deep. they are about 1" from front and back. You want it to be heavy enough to not tip easily and small enough to be moved around and not take up too much space on a table or Lap(especially useful). The front slot holds the I pad and the back her I-phone.
finished with several coats of wipe on finish. LOML uses her hours every day. It goes on vacation (easily packed) and to the coffee shop. Simple and beautiful.
Hey, I'd like to see the plans
Cool stand, Larry. I can't see enough detail in the photos to determine the construction. Mind showing/telling us how it's done?
Re: Hey, I'd like to see the plans *LINK*
Larry Barrett
This bookstand was originally designed by Andre Roubo. It is made from a single board. It is one of those surprising things that you don't quite believe until you do it yourself. As Jack said, Roy Underhill showed us on the Woodwright's Shop.
Here's a link to the 2011 series.
http://www.pbs.org/woodwrightsshop/watch-on-line/watch-season-episodes/2011-2012-episodes/
Make me one too please!
Jerry Nicholson
I have one of those from Amazon. Not really special, works just fine. If I was going to make a new one, I would probably use my H800 3d printer rather than build one out of wood. Sounds like heresy, doesn't it!
Jerry
'Tis only a flesh wound!
Arrrr
Mark Hennebury
Arrrr...gh
Did she ask for one of these too?
Joseph Mulherin
Bill, they have a stand on Amazon for $8.99, collapsible about 2"x9" long. Good for all phones, iPADS,
tablets and laptop computers.
I bought two for my female relatives and am going to try to make a few like them from the drawings I make of their design.
OK this is overkill
When I do demos I always have trouble keeping track of the time. I built this to handle several situations. With the magnetic base I can stick it on just about any lathe, out of the way but still be able to see the time. For an hour and half demo I just click on the stop watch and start it. This was an adjustable arm I bought for photography to hold a flash. I added the magnetic base and made a holder for the phone.
Re: OK this is overkill
William Duffield
If you don't have a magnetic base for your dial indicator (a quick Google search turned up these, just for starters):
http://www.harborfreight.com/1-inch-travel-machinists-dial-indicator-623.html
http://www.tormach.com/store/index.php?app=ecom&ns=prodshow&ref=31947&gclid=Cj0KEQiAsrnCBRCTs7nqwrm6pcYBEiQAcQSznOeQfqAO4-w51PXYd2IQMjVRr8z1nA9DwSdCmkQR7kYaAsGj8P8HAQ
you can make a base starting with one of these that will be strong enough to hold an iPad:
If you need something cheaper but more mobile, I put shop lights on the ends of 3/4" dowels and drop them in dog holes around my shop. Of course there is a problem with that strategy: When you want to move the iPad stand, you have to go get your drill and Forstner bit, and she might not want holes in her desk top.
TomD
Mine is made of wire and came from the dollar store and is Awesome. Wire is the most efficient way to make anything out of metal and I am using it on my current trip with a bluetooth keyboard. But it really works best in the horizontal mode, not that good in the vertical mode. Seems a though that is a theme, some work well only one or the other way. Or you can find some that work well both ways normally at the cost of the form factor. So if there is a preference for use, or form factor...
