Question on CFM for spray gun
The packaging on a spray gun I bought says "Spray Gun requires 13 CFM at 20 PSI. I don't think my compressor will provide that. I would have to research it and I am too lazy to go out in the shed and stand on my head to read the details. It's a medium sized compressor with about a ten gallon tank.
The question would be that the 13 cfm would be to operate the gun continuously as in spraying a large object? If you are spraying small items like furniture and furniture parts and starting and stopping even a smaller compressor should be fine, right?
Re: Question on CFM for spray gun
Dick Coers
Small furniture and parts will be okay, but you will hear the compressor hammering away a lot of the time. Spraying a sheet of plywood will really put a strain on it. Biggest concern will be duty cycle and water in the compressed air. Hot air will carry a lot more moisture than cool air. So during high humidity cycles, you will be sending water down the air hose. A lot of folks hang a water separator on the compressor, and that is the worst place possible. The air needs to cool before those separators work well. You need to mount the separator a fair distance away, or choose a desiccant or paper filter.
Not "Right"
From the description of your 10 gal. compressor, I would be surprised if you're getting more than 7-8 CFM. 13 cfm units are usually 3-5hp with two piston pumps on 60-80 gal receivers all running on 220.
The result here is that while the gun will spray, you are not likely to get the fine atomization you're looking for, especially if the gun is designed for HVLP (hi volume low pressure) use, and more especially if you're using waterborne finishes. While waterbased finishes can be thinned up to 20% with water, that might not be enough to give you good results.
All that said, it seems like a very high volume demand in that gun. Where did you get it? I can understand if it's a cheapo HF deal, but better guns usually need less air to function properly and will work just fine on 7-8 cfm at 40 psi or less. My guns (Walcom and CAT) do just fine at 20 psi.
Ralph Lipeles
I've guess you could use a second tank, hooked up in series with the primary tank, to reduce the effects of the temp/humidity problem. Tanks are sometimes around when somebody has one because the compressor died.
PS
It sounds like someone has taken a turbine gun and simply fitted it with a compressed air fitting rather than making a true "conversion" gun. Turbine guns are designed to run on the very high volume but low pressure put out by thus "vacuum cleaner motor in a box" units.
It sounds to me like you bought a HVLP gun and they take a lot of air. I used one for a while and it gave my 5 HP vertical tank compressor a workout. I never liked the result and stopped using it.
My JGA 502 DeVilbiss #30 cap sprays lacquer at 35 psi and uses hardly any air. I have sprayed a door with it remote from my shop with a tiny 1 gallon compressor used for nail guns. I have loaned it and it has worked fine with all sorts of small compressors.
I don't have any water trap in my line and never experienced a condensate problem. I know it can be a problem, but apparently doesn't have to be.
I had tons of moisture problems in my business
Dick Coers
Spraying 40 doors at one time, and you get a lot of trouble in the summers around here!
The spray gun is....
One of the 3M ones with disposable cups and tips. Called PPS for Paint Preparation System. Got one new on the cheap and thought I would play with it. You Tube makes it look like the best thing since sliced bread.
Re: The spray gun is....
You described the part that holds the fluid, with no explanation of the spray gun you have attached to it. Again, it sounds like a HVLP gun and if it is you are screwed. It takes an air compressor the size of what I use to run a sander to power it.
Dick Coers
The one thing I notice when watching car restoration and building on TV, is that they spray with a fan pattern about a foot wide. Just an incredibly wide pattern for what I'm used to. The cars get a clear coat, so they may just lay that wide pattern and not worry about dry edges. That also might be why the gun uses so much air. I've sprayed with an HVLP gun since about 1990. A Binks Mach 1 was the first such gun I bought.
My mistake, it a 3M accuspray gun....
and it uses the PPS system. Comes with three or four different nozzles, apparently for various viscosities. I'm looking at trying the 1.2mm or 1.3mm for lacquer.
Hank Knight
Early HVLP guns were air hogs, and so are many high quality modern industrial grade guns. Guns that require 13 to 15 CFM @ 40 PSI are common. Advancements in the technology in recent years have produced HVLP guns that work very well on far less air. Some modern HVLP guns require only 5 to 6 CFM @ 40 PSI, and I've seen guns that require even less. It sounds like you got a great deal on an industrial grade gun. Unless your compressor can feed it enough CFMs to satisfy it, I agree with Bill: you're screwed. Best look for a gun that works in the CFM range your compressor can provide, or buy a bigger compressor.
