finish for tansu
finish for tansu
finish for tansu
Howard Pollack
I have an old tansu that is beaten up and needs refurbishment. Can anyone tell me what a traditional looking finish for it might be? Thanks.
-Howard
Re: finish for tansu
"Tradition" says shellac or lacquer, both solvent-based.
Have you tested the finish? Take a clean paper towel moistened with dna and rub an inconspicuous spot. It you get color on the towel, your finish is shellac. If nothing, retry with a bit of lacquer thinner. If no result again, you probably have an oil finish that can be rubbed down with wool and then a new coat wiped on.
Brian Holcombe
You may want to consult Ty Heineken's book or contact Chris Hall of The Carpentry Way.
Re: finish for tansu  *LINK*
Google ebook
DIY *LINK*
if you have the trees ;)
Urushi Lacquer
Whatever you use, it should probably be gloss
Dick Coers
I doubt if they used flattening agents when the old tansu were made.
Clint Searl
Clint Searl
High end tansu made with zelkova, elm, or chestnut were finished with natural lacquer. Common tansu, often of paulownia, pine, or cypress, were mostly left unfinished.
Thanks everyone
