Christmas picture frames
I'm doing some long needed framing. Until I made this sled I struggled with frames. I never could do 8 miter cuts to come out perfect when using the miter gauge on the saw. So I built the sled.
The stop might be novel. It worked well.
Re: Christmas picture frames
Looks good. I need one of those. I take it the piece in the middle of the V covers the blade? Does it also reinforce the sled? Do you cut lefts and rights? Or is it accurate enough to cut them all on one side? What blade are you using, does it cut clean enough that you don't have to shoot the miters?
Henry (Raleigh NC)
Bill and Barry
I too struggled with picture frames until I built a TS sled like that.
The joy of the TS sled is that as long as the two fences are at 90 degrees, and you cut both L and R, the angle of the joined parts will be 90. On narrow materials like picture frames, any imperfection in the 45 degree cuts is not noticeable. Tight, repeatable miter joints on all 4 corners.
Previous to using a TS sled, when I focused on just perfecting 45 deg cuts, the lengths were slightly off and the result was open miter joints. This type of TS sled, with appropriate stops as shown by Bill, takes care of both the length and angled cut simultaneously. I have on occasion added a second piece to the mitered stop - a straight piece extending past the mitered section; this piece keeps the two mitered sections (piece being cut and the stop) from slipping past each other. Sawdust build up, as for other other stops on fences, is your enemy here.
Similar exacting work can be certainly done with stops on a miter saw, but often (for me at least) the work on a miter saw is less well supported (my miter saw is free standing and not built into a bench with long stock support). For me the TS sled handles short pieces better as well.
Henry
Ralph Lipeles
I built one years ago but with a sheet of plywood as opposed to your 2 bolted on locating strips. I like yours better. The wood being cut can be clamped in place, keeping the fingers far away from the blade area.
Design questions?
I have been thinking about your sled and making some frames. Your sled cuts from outside the frames inward. If you were doing frames that required miters like on crown molding, IE with the stock sitting up on a thin edge, wouldn't it be better to have the system inverted and the stock resting against taller fences. You could still do simple miters as long as your blade could be tall enough and you could cut from inside out, leaving the show face with fewer chip outs.
