Veritas - Innovation in Tools
OT-Water Softner Salt
tom
I have finally determined what my salt usage is, 1- 40# bag per month. But I was wondering about the idea of a salt block? Anyone use these? Thoughts?
Thanks!
Re: OT-Water Softner Salt
We have to use Sodium-free (KCl) but I think you won't be happy with a block as it won't be likely to dissolve fast enough to produce the proper brine concentration needed to recharge your resin bed.
Where did this idea come from?
tom
I was looking at a local Water Softner company website and they sell both bagged and block salt.
A cow's suggestion, LOL
Dick Coers
garthinsandiego
Are you sure the block wasn't actually pellets? We used to use pelletised salt that was pressed into a small block shape but about the size of a Chiclets. Advertised as easier and less messy to use. At that time and with the unit we had you could use loose salt or the pellets interchangeably.
Blocks
Turns out older brine tanks use a shelf to hold the blocks off the bottom. Blocks have been replaced by pelletized or crushed salt.
tom
Thanks for your replies! I decided to stay with bags. Went up to Tractor Supply and bought 6 months worth.
Johanna Johanson
I go through a huge amount of salt because our water hardness is over 100 grains! I usually use one 40 lb bag of potassium and a 25 lb bag of sodium chloride a week. I used to use just potassium, but at nearly $20 a bag it's pretty expensive.
Block salt probably would not work. I once got some potassium that had pellets of a centimeter or less - it clogged up my system. Now I stick with brands that have large pellets.
Lee Schierer in McKean, PA
We used to use much more salt than we do today. About 4 years ago, our timer on our softener died so it wasn't recharging. We had it repaired and the new timer works off the number of gallons used, not the number of days between recharging cycles. As a result our salt usage has been reduced by about 75%. We've noted no difference in the water softness over the old timer. Our system can use either blocks or pellets, so when we need salt we generally buy blocks unless pellets are on sale and are cheaper by the pound.
Lee
Johanna Johanson
Lee, what size are the blocks? The only block salt I have ever seen is for livestock and comes in 5 or 50 pound blocks. Those 50 lb blocks are really hard for me to carry from the truck to the corral!
The ones I buy are 50#.
Lee
Thomas E Norton
Lee, could you tell me more about this time? I was not aware that this type was available as a retro fit. I thought only Kinetic had these.
Ours is an Aquarite Supreme by Water Rite. You can set how many gallons get used before it does the recharge cycle. The installer had a table that told him what number of gallons to set for the degree of hardness of our water and teh size of our resin bed. The old system did the recycle every 7 days no matter how much water was used.
Lee
Many years ago I worked for a Propane company that also sold and rented water softeners. At the time I was trained in the softeners sizing, installation and service at the Calgon corporation factory in Wisconsin.
I rented over 100 units in one year, then looked into the salt costs. I found a supplier of "re-refined rock salt" that was guaranteed greater than 99.9% pure salt. I spoke to the factory and got an OK, then ordered a semi- load of the rock salt. It was used is most of our rental units and several competitor's units.
It worked great, what the purity amounts to, is that there is less than 1 pound of rock etc. in 1000 lbs of salt. As there is quite a large reservoir under the screen of the brine tank there was no reason to clean this out for years in normal use. At that time that salt was less than 1/2 the cost of pellet salt and dissolved in the same time frame so could be used in any system designed for pellet type salt.
Don't know where or if this is still available but it really did cut the salt cost for our customers.
I brined a turkey a couple of years ago with rock salt. It was one of the best ever. Nobody died.
