Vacuum Bag glue up questions
A friend asked me to repair a night stand. At least I guess its a night stand. It was manufactured probably fifty years ago and about half the veneer on the top was missing. Not a quality piece. The top turned out to be Lumbercore plywood with the core being poplar. The top veneer was mahogany and the under side is poplar. Have not figured out what the cross banding was. About half of that was missing on the top also.
I sliced some poplar thin with the bandsaw and made cross banding. I made veneer out of a mahogany scrap. I glued the cross banding on with Titebond in a vacuum bag. Left it in the bag for about two hours. Had a spot that did not take. Cut it open and re-glued it. Seems to be fine now.
My problem is that I am rusty on vacuum bagging.
Is Titebond suitable? Seems I remember that it drys/sets very slowly in the bag. ??? Getting ready to glue on the mahogany. What would be better glue? How about a little primmer to remind me what I am or should be doing?
Its been three or four years since the last time I used the bag. Seems I used to get more vacuum. I'm getting 18 or 20 inches of mercury as vacuum. Is that enough?
Re: Vacuum Bag glue up questions
don stephan
Haven't used any of my vacuum bags in a while, but I think I get to 26-27 on the vacuum gauge.
Can't offer any experience with white or yellow glue in a vacuum bag, I'd suggest a test pressing inn the bag with the glue, let cure overnight, then try to break apart.
If your tabletop is flat, you might want a 1/4" or 1/2" caul on top to even out pressure on the veneer. If not perfectly flat I've used heavy sail canvas, some use some type of rubber sheet to accommodate slight differences in veneer thickness.
jessecloud
Hey Barry,
That's plenty of pressure. I am at pretty high altitude so only about 19 psi is available, but I've never had a problem, and I have several pieces out there that are 10+ years old.
Yes, you do need cauls!
Plain old titebond works fine, but if you are worried about toxicity, Unibond or a formaldehyde glue is more rigid.
Just be sure the glue is spread evenly with not enough for a massive squeeze out or not so little that it dries out before it gets pressed. My rule of thumb is to make some pencil marks on the substrate and add glue until you can just barely see the pencil marks.
If you are getting low pressure, you probably have a small leak somewhere, most likely in the opening that you close to seal the bag, but also look for punctures, etc.
Happy pressing!!
I pressed the mahogany onto the piece last night. Used titebond 111 on it. This time I put it on with a roller and tried to get it "just right". Seems to have worked well. I am about to go trim the edges.
Did not use a caul. The mahogany was of slightly variable thickness and I just used some netting voe it and rolled it with a hand roller after the bag was at full pressure. Next time I will use a caul.
Thank for the help and encouragement.
Tony - Memphis
I use a layer of pond liner from Lowes under the caul to make up for any uneveness. I use plastic sheeting directly on the wood, then the rubber, then the caul. Same on the bottom if I am veneering both sides at once. I have used every glue in the shop and they all worked fine. Oh, my shop is temperature controlled too. My setup is a small Vacupress home shop pump with various purchased and homemade bags. I get around 20ish normally.
Tony
don stephan
Be careful if you use a drum sander after pressing without a caul. If the glue was not uniformly thick the surface of the veneer may be correspondingly uneven.
Found out the hard way.....
Glued shop made veneer on the panel with titebond. First glued on the cross banding. Then the mahogany. The mahogany was about an 1/8" thick and slightly variable. Sanded it to about a 1/16" all the way around the edge of the panel. Beautiful even thickness on all four edges. Sanded the next grit with a ROS and cut throughout the veneer pretty much dead center. Turns out the panel bulged in the center, I'm guessing from the water in the glue. Starting over.
Re: Found out the hard way.....
jessecloud
Sand the veneer in the drum sander before gluing to the substrate.
Joe Woodworker sells a mesh that you can use instead of a caul for curved or irregular pieces. Bends enough to get into the odd spaces but it strong enough to protect your bag from getting damaged on sharp surfaces. www.joewoodworker.com
It was SUPPOSED to be FLAT......
I think the water in the glue caused this old dry panel to turn into a dome. It had a very slight bulge in the center after I applied the cross banding and veneer. I did not notice it but I did not check it with a straight edge until after I screwed it up. I had sanded the failed veneer and cross banding off so I thought the panel was flat or at least flat enough for the drum sanding. Did not see that coming.
Are you only putting mahogany on one side?
Dick Coers
You have to always balance veneer construction. Putting mahogany on only one side and the panel will move a ton.
Re: It was SUPPOSED to be FLAT......
don stephan
Depending on several different factors, it is possible for the vacuum bag to draw down first against the edges of the panel before the middle, possibly pushing glue from the edges towards the center. Even a 1/4" thick caul will help with this.
Didn't realize you sanded back and reused the existing. Did that once on a panel my collaborator had ROS sanded to remove old paint and such. Told him a straightedge showed it wasn't flat enough to veneer, he said do it anyway. Neither of us was happy when the veneer bubbled in places. Don't think I'll ever agree to reveneer a piece again.
Keith Newton
For all the work you've done, I suspect you would have been WAY ahead if you'd just glued up some solid mahogany or Sapelle and made a whole new top.
I've been bagging for over 30 years, but I only want to do it if I can use some really special wood that makes a big impact.
You are correct, It would have been easier
to make a new top. This is why I hate furniture repairs and doing favors. This is a crappy little nightstand. It had a 14" by 17" top of lumber core plywood with no edge banding. Stained that dark purple red they call mahogany. The veneer on the top side was ribbon stripe mahogany and poplar on the bottom. Fifty percent of the veneer and cross banding on the top was ripped off. I had a piece of ribbon strip mahogany that was too thin to be the top, so I resawed it into thick veneer. I also resawed enough poplar to be cross banding. Dragged out the vacuum bag I have not used in five years and applied the cross banding. Did not use enough glue so I redid that. Applied the mahogany with more glue and tried to sand it flat, only to discover the panel had bulged upward over night, probably from the water in the glue. I was trying to reconstruct the lumbercore plywood. Bumbling toward the future.....
If this does not work,. I think I will go today and buy enough mahogany to remake the top out of solid wood and not say anything about it to the owner.
William Duffield
Why buy a fancy mesh product? A layer of fiberglass window screen added to the sandwich right on top of the show surface makes it a lot easier for the pump to suck out the extra air and water.
Been there!
Tony - Memphis
Well, maybe at least you'll learn some stuff and gain something from the experience!
I guess I'm chicken, I've never been brave enough to use power sanders on veneered surfaces. I really enjoy making veneered pieces, but that IS much different that repair work. And I love it when they ask followed by..."I'll pay you!"
Hope you can get it straight.
Tony
I did not buy the fancy mesh. I use shelf liner mesh. (Is that a mistake?) My entire bagging system is cobbled together, like much of the rest of my life. My neighbor gave me the vacuum pump many years ago. It sat on the shelf until the notion to veneer something struck me. I have looked at The Joe Woodworker site and would like to set up a rig with the reserve tanks and check valves and whatever, but have not taken the plunge.
I think I will try window screen. The bugs won't notice an 18" square hole in one of my screens will they?
Re: Been there!
These were pretty clunky veneer. When I have my bandsaw tuned up I can cut veneer a 1/16", but was not willing to take the time to put a fresh blade on and tune it, so I sawed these well over and 1/8".
The plan was to reconstruct the top side of the lumbercore plywood. Put cross banding on and sanded it to about a 1/16". I had sanded the panel flat to remove the rest of the damaged veneer, so I thought it would do the job nicely. Apparently I did not have enough respect for the water in the glue. The arch in the panel was about a 1/16" Just did not see it.
I have finally beaten it into submission. Does not pay to try to rush or take short cuts.
