OT-Computer question
tom
I have both a tablet and a laptop. Is there a way to transfer an Excel file from the laptop to the tablet?
Thanks!
Re: OT-Computer question
jessecloud
Lots of ways. If you can get to email on both devices, just send the spreadsheet as an attachment and save it on the target device.
If they both have USB ports, a flash drive/memory stick can do the job, just copy it to the stick, eject stick, insert stick in other device, and save it to target device.
Let us know if neither of these work and we can suggest many more options.
look to the cloud!
Joseph Piotrowski
if these are recent machine you probably have a apple,google or Microsoft account.
you already have a large storage space available to you. there are many other free cloud service like dropbox available for free. some pay ones too
you can access you files anyplace you can log in from. that means you won't need duplicate or worry about one version of a document on one machine and a another elsewhere.
you just need to save the file to the location on the cloud service.
i wouldn't save SSN numbers or anything like that but for non-sensitive data it great.
lot more to this and well worth looking into it.
Jerry Nicholson
1. If your computers connect to a router, set up sharing so you can send files from one to another.
2. Sneakernet, ie use a USB thumbdrive to carry files back and forth. I do this often even though my computers are networked.
Jerry
TomD
Another option is normally tablets charge off USB cables (like phones). (The one I have you can't plug a USB into, or even a regular SD card). The USB cable can be plugged into the laptop, and then the laptop should recognize the tablet as though it were an external drive, it will be in My Computer (if Windows) as a drive like F: or E:. You just go there and move files at will as you would between any two directories.
In some cases you have to use a particular port, usually the ones that are higher ratings like USB 2.0 on older machines, or maybe a 3. If the machines are picky they may assume one port selection means you want to charge, while another means you want to connect. So if at first you don't succeed, try another port.
Walt
To expand a bit Jerry's answer. If your router has a USB port - many of the newer ones do - you can plug a USB drive into that port and information stored on that USB drive will be available to any user connecting to that router. It's also a backup though vulnerable to anything that would damage the router such as fire, flood, theft. But typical computer failures shouldn't affect the data on that flash drive.
