Mitre saw dust control
Lee
I need to get my Mitre saw dust under control. I'm looking for a little inspiration, and wondering what your solution is to this dust making beast!
Pictures or links would be very much appreciated.
Many thanks
Lee
Lee
Many thanks
Lee
Re: Mitre saw dust control
Woodcraft and Rockler have the table top dust collector hoods. Those aren't too bad if you have a good dust collector w/ lots of CFM.
Rousseau sells a $150 dust hood (available at Woodcraft).
I use my miter saw outside most of the time, so I don't worry about it. I do have a table top hood for my shop which I use inside. It works reasonably well.
Joseph Mulherin
You might try making your own using cardboard and the 4" exhaust to your vacuum pump or dust deputy
+1 On The Rousseau
Dave's Not Here
I have the Rousseau and it works extremely well for me. It is rather large so you need to have the space behind the saw to make it work. I would estimate that before I bought it I was collecting maybe 10-15% of the dust created with my miter saw hooked up to my shop vac. Now, I'm probably collecting almost 100% of the dust. They are a bit on the expensive side but it doesn't take long to pay for itself in saved clean up time.
Shop-Made
I got tired of the boxes, scoops, etc. that just wouldn't handle the stream that came off my LS12-11. I decided to make a combination stand and collection hood with drop-down extensions, lights and storage. Here 'tis.
The hood was "formed" with 1/4" ply and then fiberglassed. I use a 2hp DC and 6" ductwork. The hood has 6 2" openings and the space behind the saw is a funneled drop box to a 1/2 x 5 slot.
Power supply for the saw goes through a switch in the cabinet that also powers the lights. Safety feature for small people visiting the shop.
It did a good (but not complete) job until I made an air curtain out of 3" strips of 7 mil Vizqueen that got stapled to the front rim of the hood (not in the photo) that hang just below the counter. Now nothing escapes.
Memsahib asked if I was making furniture for my tools
I expect pushback but how clean do you want to be?
Gary Smyth
If you are going to work in wood (or metal) you are going to make "dust".
I understand that commercial shops have to meet EPA requirements and also have employees to take care of, but in my shop it's only me.
I want to remain healthy but I find that a fifty cent mask and a ten dollar broom beats a $165 hood almost all of the time. Yes, I have a shop vacuum and I even rigged a squirrel cage air filter several years ago, but if I'm working on something they rarely get turned on until I complete what I'm doing with the tool and I'm moving on to finishing or whatever.
As for the miter saw, I have a platform, with electrical conduit bent in a inverted "U" shape. Mounted on the conduit will soon hold a nylon shower curtain (the canvas one I had collected as much dust as it stopped). A cannibalized swimming pool hose fits the back of the saw shoot and debris is directed into a box underneath. What remains on the platform is swept into a inset that allows stuff to drop into the box. Total cost was $5 for the conduit and $8 for the shower curtain. The platform cost about $18. It stops and catches maybe 80% or more of the big stuff. For me the rest is of minimal concern.
I tend to build stuff that fits some house need whether it be made of wood or something else. For my use, a spic and span shop is well down the list. Others will have different motives and I won't argue, but whatever you decide think of cost vs. benefit.
William Duffield
An associate of mine decided he needed one for a project requiring lots of chopping. He set up a temporary one of cardboard duct-taped together so he could experiment with shape, size, etc., intending to replace it with a permanent one made of plywood after he had the bugs worked out. The original worked so well, and was subject to so few stresses, that he is still sing the original prototype 20 years later.
Most of the dust from both chop saws and radial arm saws is expelled back tangentially from the bottom of the blade, where it rapidly decelerates and drops when it hits the back of the dust hood. The optimum placement of the 4" hose to your dust collector is straight down directly below the backstop. If you want to get sophisticated, you can connect the hose to the bottom of a horizontal sliding panel, and link the panel to the rotating frame of the saw. Such an arrangement might allow you to reduce the distance between the fence and the wall behind the saw (a significant design advantage to the Bosch Axial Glide and Festool Kapex saws). Since you might want to make this fence as long as possible, moving it closer to the wall can be a significant advantage in a small shop.
Re: How clean do you want to be?
Documented health reasons aside, I need the shop as dust free as I can make it for several reasons.
First, my office, with computers and other business machines, shares the basement with the wood shop. Wood dust doesn't do my computers, drives, scanner, fax, printers, or copier any good whatsoever.
Second, wood shop dust easily migrates into the rest of the house. SWMBO is not real high on dusting all the nice stuff I made for her only to turn around 2 hours later and do it all again. I had to move the lathe out to the garage as even with a 6" system and a JDS running, I couldn't keep turning dust under control.
I use a mask from time to time; usually when turning certain woods. The problem is the really bad stuff hangs in the air for hours. Take off the mask to answer the phone and you might just as well not have used it to start with.
At least in the garage I can run a couple of box fans and blow it all outside.
I have a chop saw set up I a "box". I made what is basically a shelf with a back and hood and sides. Vaguely similar to Mr Mandell's, but not nearly as nice. There is a slot in the bottom of the back about 2" by 10" attached to an HVAC fitting that converts it to four inch diameter duct to my Dust Collection. I have the DC blast gate beside the box and there is a micro switch on the gate that turns the DC on.
The idea is that the saw throws the dust rearward and the suction from the slot grabs most of it. Works very well unless the saw is angled toward the corners beyond the reach of the suction. I intended to put some sloping pieces in the corners to funnel the dust toward the suction, but it did not happen. The sawdust solves the problem by building up the the corners and sculpting itself. from a health safety standpoint, this sawdust is relatively harmless. Its the really fine stuff that floats in the air and gets inhaled deep into your lungs. The suction grabs most of that. You need air flow into the box.
I like the idea of the flexible flaps someone mentioned above.
You would need a deeper box for a compound sliding miter saw.
Ray Newman
JL: I just looked on the Rockler site and did not find/see the" table top dust collector hood" that you mentioned. Is this it: Mini -gilp dust hood--
www.rockler.com/mini-gulp-dust-hood
Or, I could have missed it. Do you have a part number, picture, link, etc.
Found it at W'dcraft!
Ray Newman
Found one at Woodcraft -- www.woodcraft.com/product/144614/tabletop-dust-collector.aspx
believe at one time it was labeled as the "Big Gulp"!
