Cold weather and glue
Joseph Piotrowski
Hello good people!
My shop has no heat right now and it's getting cold out. It probably be 40 or 50 in my shop. However I want to keep on working. The projects do far are all shop stuff.
I would like to glue up some pine. Edge joining in this case. What is a good glue type to use in this situation?
TIA,
Joe P
Re: Cold weather and glue
AZ in Colorado Springs
I'm doing something very similar at the moment, but using poplar.
I brought the pieces into the house last night, to let them warm up. Then today I'm doing the clamp-ups in the basement with usual titebond extend.
My shop is not heated either except for a little barn heater. It actually does a pretty good job, but my shop is small, a one car garage. You may have to make some arrangements for some sort of heat. A small heater may keep an area big enough for a glue up warm enough. Infrared heat lamps may work well. And I have heard of people using and old or cheap electric blanket and put it under or over the workpiece.
Many years ago in a different very cold workshop I glued up a cutting board for some friend visiting for Christmas. Don't remember the glue but when we took the clamps off it just fell apart, leaving a white coating on the pieces.
OTOH, I have had complete success Glueing things up with Titebond in a warm environment and then moving them into the cold shop the next day. In other words, as soon as the bond is thoroughly set, it seems to lose its sensitivity to cold.
Re: Cold weather and glue  *LINK*
I would not recommend using any glue or finish (bar some specialty ones) at those temperatures.
That's my take on it. I don't apply glue or finish until the work piece and material is at least 50 degrees F.
Heat your work pieces (infrared heater or whatever). Make sure your glue and finish are at a working temperature.
From Titebond:
Titebond III ultimate - above 47 F
Titebond II premium - above 55 F
Titebond original - above 50 F
Go to their website and click on "Take me to a specific product" in the upper right corner. You can click on the product and the the application guidelines.
Titebond
Keith Newton
My shop is pretty large with high ceilings, and hard to heat when it gets really cold out, so what I do, is make a little tent over the wood or project with a small space heater blowing in to warm it up, or bring the smaller parts into my studio.
glue performance at low temperature
Glue based on latex technology, which includes any of the white or yellow glues, must be used at a temperature that enables coalescence of the latex particles. Detains vary with the exact formulation but somewhere around 50-60 degrees they fail to bond.
The technical information on any adhesive will include the temperature range acceptable.
In general it is not a good idea for several reasons to attempt gluing in a cold environment. The kitchen floor with news papers is a choice. Assemble before going to bed and the assembly can be moved to the cold shop in the morning.
William Duffield
it just fell apart, leaving a white coating/blue]
I've had that happen with Titebond III, one of the first times I used it. I was thereafter wary of using it again, until I learned that was what it was supposed to do. ;) Now that I've gained a better understanding of it's properties, it has earned a place in my shop. I use it many places where I would have previously used epoxy, thus saving a lot of time and expense.
TomD
I have the same situation in my shop. At some point you have to give in. For what you are doing Titebond I is all you will ever need. My advice is learn one well known local glue. Avoid new products like II or III that have little advantage indoors. If you spread T1 if the smear out turns white, it is too cold. You can carry a small bottle in your clothing to keep it warm, but the parts still need to be warm. People used to work in these conditions all the time. You can use hot hide glue in pretty cold temps, they would warm the parts and use extra heavy applications of the glue. Hide cleans up easily and chunks can go back in the pot.
You have to be very careful that stuff you glue up isn't going to fall apart when the seasons change. Locally I haven't had a problem.
