Re: O.T. Electrical Question...
Grant Smith
Hi Darita,
I will speak in general terms, then get to your particular question:
The key thing to remember is that the outlet on the wall, and the wire between it and the supply panel must by code be protected by a circuit breaker or fuse that will trip before the wire or outlet is overloaded. This means you can't (legally per codes) install a larger outlet on the wire than the wire is rated for in that situation. You didn't ask that though, so this may or may not be a useful statement to you. I think it is worth mentioning so other folks reading this can get their heads around the thinking on such things.
You can, however, make the adapter you describe and use it for the welder you describe. The circuit breaker should protect the outlet and in wall wire if it was installed properly. Apparently, the welder maker decided to use an oversize plug for their welder, perhaps to standardize their line, or perhaps that particular plug is common in similarly sized welders.
You could also just change out the plug on the welder to match the outlet. Both would be OK. Just know that if you find that the breaker trips often (It shouldn't, if the manufacturers info is correct), you may need to run larger wire in the wall than what was likely there before upgrading the outlet. This assumes the electrician who installed the wall plug used the minimum sized wire necessary for the installed outlet, which may or may not be the case. I'd talk more about wire size, but there are variables such as distance of run, conduit, and wire type that figure in, so I will leave it at "It's complicated".
Enjoy the new welder, and get yourself a 4" or 4.5" angle grinder to cut parts, clean surfaces of rust, and grind away mistakes. If you buy one, make sure to get plenty of cutoff wheels, grinding wheels, and maybe a wire cup brush to have on hand. I do not recommend wheels of other than those made by major tool makers. The store branded or Harbor Fright type wheels will not likely perform as well. Get yourself a face shield in addition to the welding helmet and thank me later. Wear light leather gloves when grinding, and don't grind or weld around your woodworking area without doing a thorough cleanup and then staying in the shop for a few hours afterward to guard against fire.
And make sure to have a fire extinguisher, recommend at least a ten pound extinguisher.
Regards,
Grant in Iowa
