Disc Sander Wiring
Disc Sander Wiring
Disc Sander Wiring
Stuart Johnson
The run capacitor on my Laguna 20" disc sander blew. After getting no help or even acknowledgement from Laguna I was able to purchase a similar but larger replacement from Granger. I will need to build a new box to hold both the start and run capacitors but that isn't my problem.
I took photos prior to disconnecting everything but somehow deleted them. The attached shows the wiring diagram (right set) and a photo of the box. The top row of the wiring from left to right: W2 U2 V2, the bottom is U1 V1 W1.
Am I correct in connecting the hot to the W2 U1 strip, with the run capacitor connecting to the same strip and W1?
I realize I have to make some repairs to eliminate the burned wire (the hot melted in two).
Re: Disc Sander Wiring
Bill Howatt
Yes. That's what the diagram shows.
Bill
