Anybody replace bearings n Delta/Rockwell jointer?
I am looking at replacing bearings on my Rockwell jointer, similar to the Delta 37-220, I bought in 1972. Apparently there are at least three or four variations. There appears to be a bolt that comes up from the bottom that holds the housing down. ????? Can you remove the bearing housing without removing the jointer from the stand? Trying to figure out how much work this is going to be.
I am considering replacing the cutter head with a Shelix. Been e-mailing back and forth with Byrd. They are aware of all the variations and have sent me five various plans. Now I have to figure out which one is mine. Trying to do this without having the machine out of commission too long.
Re: Anybody replace bearings n Delta/Rockwell jointer?
Dick Coers
I removed a head from a Grizzly knockoff years ago. You can remove the head while still on the base, but it's not easy. The bolt can trap in a box end wrench between the jointer and the base. If you loosen both bolts a little at a time, you can lift up the head slightly and keep backing out the bolts till the head comes out. If the head stays down in the cradle, the bolts hit the base before the threads come out of the bearing blocks.
