Sandblaster Question
tom
I have a Siphon type blaster from Tractor Supply that works great. The only drawback is the sand pick up hose is so thick it limits maneuverability. Has anyone modified one with a more flexible hose? I was thinking clear plastic. I know it will not last as long but it could then be replaced.
Thought?
Thanks!
Re: Sandblaster Question
TomD
Don't think you will get hurt trying it...
Hank Knight
Tom, I don't have any thoughts about a flexible feed hose; but, if you have never done sandblasting, I have a recommendation for you: wear full sealing goggles. I bought an inexpensive sand blasting outfit to remove rust from some old hand planes. I used glass beads for the media. I had enough sense to wear eye protection - I thought. I wore a pair of those plastic eye shields with open vents in the sides. Sand blasting media bounces in every direction and covers you. I spent the next morning at my eye doctor's office while he picked hundreds little glass beads out of my eyes. It came in through t he side vents - very painful! I bought a pair of full sealing goggles and they worked like a charm. So did the sand blaster.
tom
Thanks for the warning.
I am building a sandblasting cabinet. I made a temporary one earlier this year and this one I have modified the size and am making it a knock down unit. It is made out of 1/4" ply on a frame work. I will be using it for re-finishing bicycle frames. By using a "sacrificial" baker panel, behind and under the item being blasted, it will protect the 1/4" ply. I would post a pic but I have not had any luck with that process in the past.
Ralph Lipeles
How does the sand get out of the cabinet? I have a homemade sandblaster with a 1 1/2' by 3' cover that hinges up to access the sandblast area. When hinged down, it sits on a framed ledge. I hook up my dust and chip collector to further reduce possibility of grit leaving the cabinet. I do not find any grit getting out of the cabinet.
tom
What I did for the first unit and will do for the second is this. I cut a hole in the bottom of the cabinet and have a 4-5 gallon pail underneath with the edges sealed. I put my siphon hose in the pail. I use a small broom/brush to sweep the media back into the pail. Quite low tech! I know that "real" cabinets have a sloped bottom but I wanted to limit the OAL size. I use my shop vac to keep the dust down and it works well. Lights are my next challenge.
