Chop saw accident
Chop saw accident
Chop saw accident
Jerry Gibbs
Saw a news clip where a worker in Mass was killed when a chop saw "kicked back". The worker was hit in the neck and killed. If anybody has the details I would appreciate sharing so we can learn.
Re: Chop saw accident
Further info
Jerry Gibbs
Apparently the man was using a K12 rotary saw, which is a large hand held tool. The saw kicked back and cut his throat. The man was cutting a pipe. Looks like a tool most of us would not use.
Re: Further info
Brian Holcombe
That is terrible to hear, my condolences to the family.
bud
If that was a K12 saw it's a chain saw engine with a 12 inch table saw blade instead of a chain and you pull it toward you to cut. I've used one as a firefighter to cut holes in a roof to let smoke and heat out. I was a LOT younger then and could hang off a ladder cutting with that saw in rain, snow and ice. Scary now. Can use it to cut concrete and pipe with a different blade. If the blade guard is on there pretty safe but it has to be left on.
