Laguna Woes...
Laguna Woes...
Laguna Woes...
Darita
I hate to write about this experience, but I have to, cuz I know how important good customer support is to all of us who purchase machines with our hard-earned Money. Let me first say that the CS person that I've been dealing with has been kind, courteous and I'm sure, has gone out of his way to do his darnedest to help me, but I just don't think Laguna is set up to support it's customers, after the sale. I know back a while, there was plenty of talk about how poor their CS had been and I really thought that a lot of that had changed over the years, which is one of big reasons I pulled the trigger on one of their 2HP dust collectors, about a year ago.
Recently, I've been having trouble with breakers tripping on start up of the DC, so I gave Laguna a call and right away, the tech new that I needed a new start and run capacitors and that this happens often enough. I was a little surprised that he was going to charge me for them, but I was desperate and he had me over a barrel, so I said OK. He had my model # and SN, so I figured he knew what I needed.
Well, when I received the caps, they were the wrong ones, as they wouldn't fit in the little black box on the motor. I called the tech and he seemed puzzled. He asked me to send pics of the caps I had, so I did. After a back and forth, he said no one there really knew what caps I needed or knew where to get them and that he'd have to contact the home office and get some info. About a week later, he contacted me and told me that he finally found out which caps I needed, but didn't know where to get them, so he'd have to find that out. So now it's been about a month since my initial call and I still don't have the caps. I've been told that the run will be on it's way, but he doesn't know where the start cap is or when he'll be sending it.
Ya know...I'm 63 years old and have purchased a lot of machines. I've called both large and small manufacturers for support so I kinda know what I should expect. Given a model # and serial number of a machine, wouldn't you expect that Laguna should at least know what parts that machine takes and where they can get those parts? I mean, shouldn't someone there know, especially since I'm not the first person to call about this issue on this model machine? Foreign manufacturer or not, shouldn't they at least have parts lists of the machines they sell?
I don't know...maybe I'm expecting too much, but I really can't put the blame on manufacturing being done over seas. Just about all machines these days are made overseas and I've not had this happen before.
Just thought you folks should know...
Re: Laguna Woes...
Replacing caps is easy...
John in NM
Just look at the MFD rating, voltage rating, and physical size. Then order something similar from Grainger or another supplier (maybe MSC?). Matching the microfarads is more important for run caps if I remember correctly, but even there it's only within 5% or so. Voltage rating can be anything over what you are using - ie a 300V cap is fine in a 220V application. Run caps are more expensive usually, one of each might run you $50 total based on the last time I bought any.
There's a couple of regular posters here who know this stuff better than I do, so maybe one of them will speak up.
A year is a short time to lose capacitors. While I wouldn't necessarily expect them to replace them for you, I would expect them to be pretty interested in such a short time to failure - 5 to 10 years is more in line.
Re: Laguna Woes...
Re: Laguna Woes...
Stuart Johnson
I ran into the same problem with my 20 inch disc sander. After sending me two incorrect cap I finally got one that works from Granger. I am now having the same problem again though it is now the run cap not the start one. I've sent them an email with not response. I wouldn't fool with them except the blown one has a double stamp where it shows the size and you can't read it. I don't know if the size and so forth is dependent on the actual motor or the size / hp of the motor. In any event based on CS this was my first and last Laguna purchase.
Re: Laguna Woes...
Re: Laguna Woes...
Darita
Ya...def learned my lesson. I should have gone for the Oneida, but I wanted to save a few bucks. The few times I've done that, I've gotten burned.
Re: Laguna Woes...
Re: Laguna Woes...
North of the Border
Thanks for sharing. I heard about some bad stories from various woodworkers about this company before and I have stayed away from anything it carries. I will continue to do so, regardless of where its products are made (the origin is not a concern to me, it is the quality and after sales service).
As a consumer, I need not rely on any other parties to fix any machine problems other than from the party who sold me the machine -- unless it is something (including parts) that has been made obsolete. Woodworking is supposed to be fun and woes like this kill much of the fun!
Re: Laguna Woes...
Re: Laguna Woes...
Darita
Couldn't agree more...now. Shoulda, coulda, woulda...learned my lesson. That said, when it works, it works fine. Again, that said, as soon as I get this DC up and running, I think I'm going to sell and move on to a DC that I should have stretched to purchase to begin with. Time to move on...
Re: Laguna Woes...
Don't you have a local motor shop?
Dick Coers
Take it to a local shop, find out exactly what to buy from them or Grainger, forget about Laguna customer service, and have a working machine. Might take a little more money, but worth it for putting this behind you.
Re: Laguna Woes...
Re: Don't you have a local motor shop?
les winter
Is it the onboard overload that is tripping or is it the breaker in your panelboard? What size breaker do you have? Anything else on the line that is now on and used to be off?
