fixing Delta/Rockwell planer
I went to a friends shop today to fix his planer. It is a Delta/Rockwell 13" built in 1970. It wasn't feeding boards. I removed the blades last week so we could get them sharpened. He cleaned and waxed the bed and cleaned all the feed rollers. I put it back together today with the new blades and it still wasn't feeding properly. The board just stops. We adjusted both the infeed and outfeed rollers. It seems like it might be binding up on what they call a chip breaker. I just watched a video by Bob Vaughan and he calls the one on the outfeed side a pressure bar. .In the manual it says this doesn't need adjusting however that are adjustment screws. It's hard to see how that thing works. We tried adjusting it up and down and we still have the same problem. Anyone have this planer or know how to adjust the pressure bar or chip deflector. Also there weren't any specs on the blade height. He didn't have the little tool that probably came with the planer. I used my mini magnetic planer blade alignment tool to get close and then adjusted the blades with my dial indicator to within .003 of each other and end to end.
