Out Feed Size
Out Feed Size
Out Feed Size
Stuart Johnson
I’m in the process of rearranging my shop and it’s time for a new outfeed table. I’ve been thinking about the design and after watching dozens of Youtube videos I started thinking. Most tables have tracks for the miter bar and usually two for sleds. Is there any need for the slots other than when using a sled with a large panel? Even then is there a reason the table can’t or shouldn’t be moved back away from the saw enough so the bars don’t hit?
Next is ripping. A 4x8 sheet of plywood is the largest thing I’ll have on my saw possibly ripping an 8 foot strip. With a 4x4 table backed away from the saw at least 65% will be supported. I want to make the table as small as reasonable but large enough so I don’t need to worry about the size of cut. If 4x4 is a good size I will have room to make some roll around assembly and storage cabinets to sit a long side them. FWIW, I have a large shop and space is not a great consideration but I like things other than machinery to be mobile and have more than one use. For example, a planer stand with cabinet storage underneath on castors so it can be rolled around for use or to be out of the way.
Is one size preferable over another and why or is just what works for you?
Re: Out Feed Size
Re: Out Feed Size
Gary Smyth
If your shop is large and you have the capability then put in tracks. It is easier to make the miter track while the top is off than when permanently placed. You will find it convenient in the long run. I often run 15" or 20" cuts and the ability of the miter gauge to go beyond the end of the saw table a great assist.
If you make a cabinet for slots the same height as the saw table, for multiple purposes it can also serve as a roll around assembly table away from the saw.
If your saw has a motor that extends to the rear of the saw, one side of the new cabinet can be made to have a hinged flip up piece, less than the max height of the cabinet that can roll right up to the rear of the saw at the proper saw height and dropped away when not needed. In that case only the flip up needs have tracks and the cabinet itself can have a smooth top surface.
I have a contractor's saw and can only go 28" to the right of the blade, I would think that a 4' x 4' table would be adequate.
Re: Out Feed Size
Re: Out Feed Size
jessecloud
My outfeed is 4x4 and I'm happy with it. Its a very logical place to put shelves to store your tablesaw sleds and other bulky items. It also serves as an assembly table and a finishing bench.
I have slots for the miter tracks. Make the slots considerably wider than the tracks. You don't want to have to get absolutely perfect alignment with the saw every time you move the table around.
I seldom move my saw, but when I do I am glad that I put levelers in the legs of the outfeed.
If you plan to move the outfeed back from the saw to accomodate long pieces, be sure to check the feed with the blade down - you don't want to find out that the sheet sags before it gets to the outfeed while you
are pushing a piece through the running blade - don't ask me how I know that. ;^)
Re: Out Feed Size
Jim DeLaney, Austintown, Ohio
Re: Out Feed Size
My outfeed table is 5 feet square - it's a full sheet of Baltic Birch plywood, edged in cherry. It's got fixed casters under two legs so I can move it like a wheelbarrow if necessary. I've only ever moved it to clean under it, though.
It has channels cut for the miter slots. I made the channels half an inch deep and 1¼" wide to allow for some movement/misalignment. The channels are long enough to allow my cutoff sled to get a full cut - about 16" or so.
It makes a handy assembly table or auxiliary workbench when needed, too.
Re: Out Feed Size
Re: Out Feed Size
Jim Dillon
Stuart, my outfeed table on my cabinet saw is 4 feet wide by 2 feet deep with miter slots routed into the plywood (and reinforced underneath). Design-wise it is like one half of a torsion box with two legs on levelers. The long side adjacent to the TS is attached to the TS with hinges so the table could, in theory, be dropped. Sounded like a good idea at the time, but I have never had reason to lower the table. The miter slots are absolutely necessary for wider sleds. When I did my kitchen, I cut many 4x8 sheets of plywood and formica, plus 12 foot boards. I supplemented the outfeed table with an adjustable roller set several feet beyond my outfeed table. A 4x4 foot outfeed table would have been useful in these instances, but space is tight. My 4 x 2 table has been perfect for me. Hope this helps. Jim
