200+ woodworking book reviews
Questions for Bill Tindall or anybody spraying
Bill, I ordered a Devilbis Spray gun (JGA-510) off Ebay. It came with a small cup. The cup appears to be about a cup or 200ml. Do you really like to spray lees than a cup at a time? Looks kind of small to me.
And could you explain the 3M disposable system to me a little better. I looked at them on Ebay, but I a little shaky. You remove the existing Cap and dip tube and cup and replace it with the 3M cap and cup? What about the dip tube? Do you throw the "disposable" cups away or reuse them? Where can I get a lesson without driving you nuts? I'm off to check You Tube and Google.
Re: Questions for Bill Tindall or anybody spraying
A cup of material will spray a lot,
Dick Coers
unless you are spraying many sheets of plywood. I thought the 3m system had liners and is for gravity guns. No idea if your gun is suction or gravity.
Re: A cup of material will spray a lot,
Jerry Gibbs
3m pps has YouTube videos. The caps and liners are meant to be disposable. The system will work with suction or gravity guns. The advantage for me is that I can spray at any angle, including inverted. I don't see the advantage in cleaning. Cleaning the cup is easy and it doesn't prevent having to clean the gun. I use gravity feed. Jerry
Do you really like to spray lees than a cup at a time? .....Typical. Even when I was spraying house trim I only used a pint cut. The small cup will be mighty handy when maneuvering around furniture parts.
And could you explain the 3M disposable system to me a little better.....no. get thee to an auto body shop supply place the sells these items and have a demonstration.
Yes they are disposable but I sometimes reuse depending on what is in it. One can remove the cup from the gun, cap the cup and set it aside for later use. Nice for things like stain.
PS
they work like a baby bottle with liner. Liner collapses as liquid is sucked out.
Cool, Thank you
I have spent some time on You tube Looking at the system. It seems to concentrate on the gravity feed guns. Apparently they have take over the that part few the market. I will find the parts I needs and give it a try. You Tube mentions the No. 18 adapter in a 16 second clip and that's all they have to say about siphon feed guns. (EVERYBODY knows the cup is supposed to be on the bottom.)
Thanks for the help.
Re: Cool, Thank you
You need to buy a piece of pipe that connects the gun to the PPS cup top. Often you can convince someone to give you the adapter if you get the rest of the cup parts. The adapter is about $18 the last I checked.
The PPS is more ideally suited for suction feed. You can then spray sideways, upside down, whatever. Very handy. Cheap as I am I can't live without it.
And, I think clean-up is much easier. Remove plastic parts, turn gun upside down, fill adapter tube with solvent, about 10 mL. Drain and spray. Repeat one more time. Done.
