Dewal router needs long wait before turning on
Adrian Mariano
My Dewalt DW621 router seems to run ok. But when I turn it off...it won't turn back on unless I wait a while. The last time the wait was a long time, like an hour. After several minutes it still wouldn't turn on.
I thought that may be the motor felt hotter than seemed reasonable, and wonder if it could be a temperature issue. But even when it feels completely cold (on the outside) it still won't turn on. Any suggestions on troubleshooting/repair of this problem?
Re: Dewal router needs long wait before turning on
Adrian Mariano
Actually now it won't turn on at all.
Jim DeLaney, Austintown, Ohio
Check the brushes. They may not be making good contact due to commutator wear/corrosion.
Re: Ditto
Adrian Mariano
It took me for ever to figure out where the brushes were (with lots of unnecessary disassembly) but I finally found them, and they look destroyed, so I think that must be it. New brushes ordered. (I've never had to replace brushes before.)
Re: Ditto
John McGaw
Depending on what you mean by 'destroyed' you might want to mentally prepare yourself for further bad news. Sometimes when brushes wear down to nothing they will damage the motor's commutator. This can mean the motor will still run poorly and may eat the new brushes in short order.
fitting brushes to motor?
Adrian Mariano
The brushes weren't gone, but they were worn, especially badly on the corners.
Now I have replacement brushes and two issues. The new brushes seem to have a different power connector than the old one. The old one was crimped onto a connector that slide over a plate in the machine. The new one has a plate sticking out that I guess is supposed to slide into something. (There seem to be several different versions of my router, so this could explain it, I guess.) I'm not sure how to make a decent plate to plate electrical connection...other than soldering, I suppose.
The other problem is that the new brushes are too long. I can't put the cover back on the machine when they are inserted. I'm not sure how much extra length there is...maybe somewhere between 1/16 and 1/8". Can I just sand them down? I noticed that they have a ridged surface on the business end. Is that important?
Re: fitting brushes to motor?
Marc in Mass
Sounds like you have received the wrong brushes. They should fit without any changes. That said, I have modified countless brushes to fit where they were not supposed to. The wire has to make contact securly, the brush has to fit the carrier snugly but loose enough for the spring to advance it, and the spring has to be sprung enough to provide that pressure. Slightly curving the carbon face to match the contact surface aids in the breaking in. Tool may be a bit doggy until full contact is restored.
Ralph Lipeles
Brushes cut pretty easily with a fine tooth saw.
Adrian
It turned out to be rather more difficult than it first appeared to fit the brushes. I trimmed one a bit, but then I realized that the slot that held the brush was obstructed by what appeared to be carbon deposits. Eventually I concluded, however, that part of the obstruction was actually melted plastic from the machine's case. I fully disassembled the router, and cut the plastic away with a knife and chisel and used a saw sharpening file to get rid of deposits in the shaft. After this treatment, the new brushes slide smoothly and appear to be a reasonable length. (Sadly, I had trimmed one already and had to order another.)
After finding a way to wire them in I powered the machine up and it seems to be working fine now, so the repair was a success.
Re: fitting brushes to motor? *LINK*
Keith Newton
It sounds as though you may have been running it with quite a bit of arcing for a while. When brushes get too worn and short, or jammed in the holder so the spring won't keep it tight, or the commutator gets glazed, you can dress the end, and clean the commutator by touching the commutator with a little ablative stick while it is turning. The little abrasive particles come off, and travel around between the brushes, cleaning and seating both in an instant.
The better they are seated, the less resistance and power loss to heat, which means more power to the motor. This is a cheap little fix that all serious woodworkers ought to keep around to keep their tools in good working order.
Also just so you know, the electrical current in only through one brush, through the wires out to the other side and brush. The segments off on both sides don't have a current to shock you, so don't wig over getting zapped doing this.
http://www.mscdirect.com/browse/tn/Abrasives/Files-Sticks-Stones/Commutator-Cleaners?pcrid=97959250264&navid=12104073&gclid=Cj0KEQiA4JnCBRDQ5be3nKCPhpwBEiQAjwN1bpth6KY0TQnx-bNNRurgmPcI5SSyCWaIsFQ_hDDmfbkaAkzc8P8HAQ&mkwid=snQzFyoqC%7Cdc&cid=ppc-google
Adrian Mariano
Are you saying that with both brushes in place I touch the commutator with the abrasive stick? From what I recall, the commutator was pretty well covered up. (I'm assuming the commutator is the spinning part that touches the brushes.) Or do I remove one brush and stick the abrasive stick into the brush slot?
As far as I could tell, my commutator was clean, even though everything else was a mess.
Keith Newton
NO to
That would be a shock hazard.
