First things first - have you any idea how this thing got on your computer? Have you installed any new programs? Sometimes stuff like this sneaks in along with legit software. It's also possible it was installed without you knowing by some page you visited online. At any rate, things like this are better kept at bay by using a good anti-malware / adware program.
The problem with many of these "clean up" programs is they are too aggressive and may want to "clean" things that shouldn't be. Ask yourself this - if this (or any such) program finishes its scan and presents you with a list of items to "clean" from your system, are you computer savvy enough to know which to do? Or worse, are you willing to gamble and let it do it automatically and hope for the best?
My advice is if you aren't having problems with your system, leave it alone and delete it using Windows Add/Remove Programs application.
If you didn't intentionally install it then get rid of it. Just because it says that it is a 'Microsoft Partner' does not mean that it is. Even if it is what it claims to be, the mere fact that it found some way to sneak into the system says a lot about it. Just because someone hung a sign saying 'puppy' on a crocodile doesn't make it a puppy or make it safe to pet.
I remove everything that I didn't intentionally install on my computer.
I not only use the uninstall through the Windows control panel but I also scan the registry (with RegSeeker) to find all references to the program and it's manufacturer and remove them. Often software doesn't clean everything out of the registry when it uninstalls.
I absolutely hate these drive-by installs. You have to be so careful when installing any software these days because there are so many ride-along "offers" lurking in the install process that you need to decline so they don't install.
It used to be you had to opt in. Now they are forcing you to find where you can opt out. It sux!!!
Me too. It does a good job and has enough sense not to go overboard. I've never had a problem with it even when cleaning the registry and that is where a lot of "really going to fix it up for you" cleaners screw things up by getting too agressive.
I also use this program and find it works well. With that said, I still like to look over proposed changes before cleaning in case there's something on the list that shouldn't be (it's happened a few times).
As always - it's a good idea to have a fresh backup beforehand just in case.
