Brush-on Wipe-on finishes?
Jack Guzman from Maine
I finish my chairs with a "wipe-on" finish. It consists of equal parts of BLO spar varnish and mineral spirits. I apply a heavy coat,let is set for awhile,then wipe it till there's no liquid left on the surface. I then let it dry 24 hrs and repeat for a total of three coats. I started this process using a small absorbent rag dipped in a bowl of finish. After a few chairs I noticed this method was messy so I started applying the finish with a 1" chip brush that I dipped in the bowl as needed. I seemed to get good results so I do it this way all the time.
I was wondering if it makes any difference which way the finish is applied. Is there any advantage to rubbing it in with a rag? All the brush does is lay it on,there is no rubbing except when wiping it off. Does wiping with a rag help get the molecules of finish into the pores better? I'm thinking that the absorption process happens regardless of the rubbing but I am no scientist or finish expert.
So, does anyone know the answer to this?
It's funny how the mind wanders when applying finish. ---Jack
, what do you mean by the part above that is in bold?
